Hi all. I don't have many experience with http post.
Can someone please help ?
Here the execution with CURL and it work fine.
curl -X 'PUT' \
'https://xx-xxxx.xxx-xxxxxx.it/xxxxxxx/1 ... xxxxxxxxxx' \
-H 'accept: */*' \
-H 'Authorization: Basic omissisvaWxzOkhmOMISSISOMISSIS==' \
-H 'Content-Type: application/json' \
-d '{omissis}'
Here my rpg call:
H DFTACTGRP(*NO) ACTGRP(*NEW) BNDDIR('HTTPAPI')
D/copy qrpglesrc,httpapi_h
D incoming PR 10I 0
D descriptor 10I 0 value
D data 8192A options(*varsize)
D datalen 10I 0 value
D rc s 10I 0
D msg s 52A
D data S 2048A
D retdata S 32766A
D retlen S 10I 0
D nextpos S 10I 0 inz(1)
: %paddr(add_headers) );
rc = http_url_post_raw('https://xx-xxxx.xxx-xxxxxx.it/'+
'xxxxxxx/1.1.0/xxxxxxxxxxxxx'
: %addr(data)
: %len(%trimr(data))
: 1
: %paddr('INCOMING')
: 30
: HTTP_USERAGENT
: 'application/json');
RET_VALUE = http_error; that contain "This page requires a user-id & password"
http_xproc(HTTP_POINT_ADDL_HEADER: *null);
i Think the problem is here.
P add_headers B
D PI
D headers 32767a varying
D CRLF C x'0d25'
D token s 1024a varying
/free
// code to calculate 'token' should go here.
token = 'omissis==';
headers = 'Authorization: Basic' + token + CRLF;
/end-free
P E
HTTP Authentication help
giuliocarlomagno
Re: HTTP Authentication help
I have solved the previous isuue but now get another error.
SetError() £13: HTTP/1.1 405 Method Not Allowed
HTTPAPI Ver 1.23 released 2008-04-24
OS/400 Ver V7R3M0
http_setauth(): entered
DNS resolver retry : 2
DNS default domain: XXXXX.XXXXX
DNS server found: XX.XXX.XX.XX
https_init(): entered
Cert Validation Code = 6000
-----BEGIN CERTIFICATE-----
OMISSIS
-----END CERTIFICATE-----
Serial Number: OMISSIS
Common Name: *.XXX-XXXXXX.it
Issuer CN: omissis
Issuer Country: XX
Issuer State/Province: XXXXXX
Issuer Locality: XXXXXXX
Issuer Org: XXXXXXX
Issuer Org Unit: http://XXX.XXXXXX.com/repository/
Version: 3
not before: 20210915161819
Unknown Field: 16:18:19 15-09-2021
not after: 20221007174638
Unknown Field: 17:46:38 07-10-2022
pub key alg: OMISSIS
signature algorithm: OMISSIS
SetError() £49: SSL_protocol: Unknown protocol 596
Protocol Used:
do_post(): entered
POST /omisssis/1.1.0/omissis HTTP/1.1
Host: OMISSIS
User-Agent: http-api/1.23
SOAPAction: PUT
Expect: 100-continue
Content-Length: 536
HTTP/1.1 100 Continue
SetError() £13: HTTP/1.1 100 Continue
{omissis}
Date: Sat, 10 Sep 2022 19:47:27 GMT
Server: WebServer
Strict-Transport-Security: max-age=3600; includeSubdomains;
Access-Control-Allow-Origin: *
Access-Control-Allow-Methods: POST,GET,OPTIONS,DELETE,PUT
Access-Control-Max-Age: 3600
Access-Control-Allow-Headers: Content-Type,Authorization
Content-Type: application/json;charset=utf-8
Access-Control-Expose-Headers: ErrorMessage
ErrorMessage: Unknown method: POST
Content-Length: 0
X-XSS-Protection: 1; mode=block
Cache-control: no-store, no-cache
X-Frame-Options: deny
recvdoc parms: identity 0
SetError() £0:
OS/400 Ver V7R3M0
OMISSIS
Issuer CN: omissis
Issuer Country: XX
Issuer Org: XXXXXXX
Version: 3
Protocol Used:
do_post(): entered
Host: OMISSIS
SOAPAction: PUT
Content-Length: 536
{omissis}
Server: WebServer
Content-Length: 0
SetError() £0:
Hello Giuliocarlo,
That is a very old version of HTTPAPI. Please consider updating to the current version. I cannot support 14 year old versions of HTTPAPI.
With regards to the error, this API does not support the POST method -- therefore you get "405 Method Not Allowed".
In your CURL example, you are using the PUT method. Can you explain why you changed it to POST for HTTPAPI? Also, you seem to have set the SOAP Action to PUT -- which does not make sense since this is not a SOAP transaction. I think you are confused about what what these things are.
Explanation: An HTTP method is similar to an RPG operation code. Just as you might do a OPEN, CLOSE, READ, WRITE or UPDATE in RPG to tell it what to do with the data, in the HTTP network protocol, you must tell it what to do with your data (including the URL) and you must do that with an HTTP method.
The most common HTTP methods are GET, POST, PUT, DELETE and HEAD.
In the old versions of HTTPAPI, you specified the method by which subprocdure you call. So the old http_url_post_raw() procedure always does the POST method... that's why it's called "http_url_post_raw" instead of something else. (There is also an http_url_get_raw if you prefer to use the GET method.) Back in the time when these routines were written, GET and POST were the only methods that most systems supported, so only those methods work with the http_url_XXXX subprocedures.
In newer versions of HTTPAPI (Since 2017 -- so 5 years ago) there are easier to use routines such as http_req(), http_stmf() and http_string(). These accept the HTTP method as a parameter, so can be used with any method.
Also, I see that you've coded your own routine for Basic Authentication. While that's possible (and you seem to have it working), I would discourage it -- please consider using the built-in routine http_setAuth() in HTTPAPI unless you need a special feature that it doesn't support.
http_setAuth(HTTP_AUTH_BASIC: 'userid-here': 'password-here');
http_setOption('timeout': '30'); // Timeout after 30 seconds
http_setOption('network-ccsid': '1208'); // Expect data to be UTF-8
rc = http_req( 'PUT'
: 'https://xx-xxxx.xxx-xxxxxx.it/xxxxxxx/1.1.0/xxxxxxxxxxxxx'
: *omit
: ResultString // String to receive the results
: *omit
: %trimr(data)
giuliocarlomagno
Thank you Scott. I proceed to upgrade HTTPAPI at last version.
BR
Giulio Carlomagno
BR
Giulio Carlomagno
giuliocarlomagno
Hi all and thank you Scott.
After LIBHTTP upgrade to last versio, now all work fine.
OS/400 Ver V7R3M0
DNS default domain: XXXXX.local
QSSLPCL = *OPSYS
Support for TLS 1.3 unavailable.
initializing GSK environment
GSK Environment now available
SNI hostname set to: xx-xxxx.xxx-xxxxxx.xx
omissis
Omissis
http_persist_req(PUT) entered.
do_oper(PUT): entered
PUT /omissis/ HTTP/1.1
Host: omissis
User-Agent: http-api/1.45
Content-Length: 536
{"omissis"}
Date: Wed, 14 Sep 2022 17:18:52 GMT
Server: WebServer
ErrorMessage:
Content-Length: 0
recvresp(): end with 200
recvdoc(): Receiving 0 bytes.
OS/400 Ver V7R3M0
QSSLPCL = *OPSYS
omissis
Omissis
Host: omissis
Content-Length: 536
{"omissis"}
Server: WebServer
ErrorMessage:
Content-Length: 0
Good to hear! Thank you for letting us know.
Hello Scott, hello forum. I am setting up a program to access a webservice.
It is always telling me the message of: DSPLY This page requires a user-id & password.
The code of my program is the following:
D CRLF C CONST(x'0D25')
D rc s 10I 0
D msg s 52A
D MyapiKey c const('"KEY_xxxxxxxxxxxxxxxxxxxxxxx-
D xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx-
D xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx-
D xxxxxxxxxxxxxx"')
D fromAddr s 100A varying
D Subject s 100A varying
D Message s 1000A varying
D myPointer s *
D dataSize s 10I 0
D formData s 32767a varying
D op s 50A
D userid s 50a
D pass s 50a
D Url s 100a
D ResData s a len(16000000) varying
D http_getauthLo s 1000a varying
/free
//http_debug(*on);
http_getauthLo = '/tmp/http_getauthLog.txt';
http_debug(*on : http_getauthLo);
formData = *Blanks;
// Montar autentificación
userid = '{"API-KEY":';
http_setAuth(HTTP_AUTH_BASIC: userid: MyapiKey);
// Montar tipo de archivo con que trabajar
http_setOption( 'content-type'
: 'application/json' );
// Montar datos a enviar
formData = '{"useid":1, "title:":"foo", "body":"bar"}';
formData = %Trim(userid) + MyapiKey + '}';
// Montar Url donde acceder
Url='http://web.xxxx.net:9600/xxxxxxxxxxxxxxxxx';
rc = http_req( 'POST'
: %Trim(Url)
: '/tmp/prova001.txt' // File to receive
: *omit // String to receive
: *omit // File to send
: formData ); // String to send
// Control de errores retornados por el servidor
if rc <> 1;
msg = http_error();
dsply msg;
cmd('DSPF ''/tmp/prova001.txt''': 200);
// Fin del pgm
Thank you very much for your help.
D rc s 10I 0
D msg s 52A
D xxxxxxxxxxxxxx"')
D myPointer s *
D dataSize s 10I 0
D op s 50A
D userid s 50a
D pass s 50a
D Url s 100a
/free
//http_debug(*on);
formData = *Blanks;
: %Trim(Url)
if rc <> 1;
msg = http_error();
dsply msg;
// Fin del pgm
You appear to be putting part of (but not all of) a JSON document into your userid, which doesn't make sense to me. You'll need to read the documenttion for this API to determine how the userid/password is meant to be transmitted. Is it using basic authentication? If so, you don't use a JSON document -- just pass whatever code they use to designate an API key (typically 'apikey', or 'api-key' or just 'key') as the userid, and the key as the password. No JSON characters.
If they expect it to be transmitted as a JSON document, then this is sent in the payload, not with basic authentication.
You'll need to read their documentation -- every API is different.
