How to find current version
lindaprowse
Post by lindaprowse »
I see posted 'Please mention the version of HTTPAPI you are using. If you're not sure, look inside the HTTPAPI_H copy book, and search for the HTTPAPI_VERSION constant.' But am unable to find the HTTPAPI_H copy book?? Can someone please guide me on this??
vhamberg
Re: How to find current version
Post by vhamberg »
Hi
A copy book is a member of a source PF - it would have to be one of the source PFs in the library where you put HTTPAPI.
Hope that gets you in a helpful direction.
Vern
lindaprowse
I am not having any luck. I checked our library (LIBHTTP) and don't see anything in any source file with that name.
In QRPGLESRC in LIBHTTP there is a source member CHANGELOG.TXT which lists versions and changes. Not sure if I have the latest version on my system but it shows 1.39 as the latest change.
lindaprowse
Ah Hah!! That's it! Thank you so much! I am at version 1.24 so I definitely need to upgrade!
