HTTPAPI Performance questions
assignment400
Post by assignment400 »
Scott,
I have developed my first program to consume a REST web service rendered by SAP. I am using HTTPAPI but not YAJL. The program is working as designed so results are good but there is a lag when the web service is consumed. What type of timing should I expect from the API's vs the delays while waiting for the web service to respond?
The times I am seeing are
- preparing to call is about .02 seconds
- Consuming the web service is between .8 to 5 seconds
3 fields are passed in addition to the header stuff: Code 1 = 3A, Part = 15A and the quantity (returned) = 25A.
I also see the first call takes longer than the rest of the calls.
I am trying to improve the 5 seconds.
Is there anything I should look at?
TIA, Darryl Freinkel.
assignment400
Re: HTTPAPI Performance questions
The version should be current. I downloaded it in the past month.
<snippet>
request = '{'
+ wQQ
+ 'CustomerAccountNumber'
+ wQQ
+ %trim(dsRequest.CustomerAccountNumber)
+ '", "AuthKey" : '
+ %trim(dsRequest.AuthKey)
+ ', "Parts": ['
+ wQQ
+ %trim(dsRequest.Part_no)
+ wQQ
Response = http_string('POST': url : Request :
'application/json');
wHttp_error = http_error();
// return the result
</snippet>
assignment400 wrote: Wed Oct 12, 2022 10:18 pm The times I am seeing are
What is meant by "preparing to call" and "consuming the web service"? How are you deriving these numbers?
assignment400
I have attached a copy of the logging I do in the program. I log a record when the program is called, when it calls the SAP program (web service), when SAP responds and when I return the data to the calling RPG program.
I made a small change this morning to do a RETURN and not set on LR and that helped some but the times are still about 3 seconds per call.
I am including the code here.
      /if defined(*CRTBNDRPG)
         Ctl-Opt DFTACTGRP(*NO) ACTGRP('KLEMENT');
      /endif
       Ctl-Opt option(*srcstmt);
       // Ctl-Opt BNDDIR('HTTPAPI':'YAJL');
       Ctl-Opt BNDDIR('HTTPAPI');
      /include httpapi_h
      //include yajl_h
      // Procedure interface - passed Parameters
       dcl-pi json_05    extpgm;
         pCustomer          char(3);
         pPart_no           char(15);
         PQuantityAvailable Char(25);
      // Local Variables
        Dcl-S uri               Varchar(5000);
        Dcl-S url               Varchar(2000);
        Dcl-S rc                Int(10);
        Dcl-S target            Char(3);
        Dcl-S result            varchar(2000);
        dcl-s request           varchar(2000);
        dcl-s response          varchar(200);
        Dcl-S wQQ               Char(1)    inz('"');
        dcl-s wScan_Found_at    int(10);
        dcl-s wField_Start      int(10);
        dcl-s wField_end        int(10);
        dcl-s wPart_No          char(15);
        dcl-s wQuantity_in      char(15);
        dcl-s wQuantity         int(5);
        dcl-s wMessage1         varchar(256);
        dcl-s wMessage2         varchar(256);
        dcl-s wMessage3         varchar(2000);
        Dcl-S wCmd              Char(3000);
        Dcl-S wCmdLen           Packed(15:0);
        dcl-s wTime_Called      timestamp;
        dcl-s wTime_SAP_Called  timestamp;
        dcl-s wTime_SAP_Responded timestamp;
        dcl-s wError            varchar(1000);
        dcl-s wHTTP_Error       varchar(2000);
        dcl-s wRcd_Type         like(Rcd_Type);
        dcl-s wCount            int(10);
        dcl-s wAccess_Key       char(30);
        //Program status Data structure
        Dcl-DS PgmStatus  PSDS;
          #Program       Char(10)   Pos(1);
          #dbLib         Char(10)   Pos(93);
          #job           Char(10)   Pos(244);
          #user          Char(10)   Pos(254);
          #job_number    char(6)    Pos(264);
        End-DS;
      // data structures
        Dcl-DS dsICLOGP  extname('ICLOGP');
        End-DS;
      // REQUEST data structure
        Dcl-DS dsRequest  qualified;
          CustomerAccountNumber Char(10);
          AuthKey        Char(128);
          Part_No        char(15);
        End-DS;
        // Dcl-DS dsPart  qualified ;
        //   Part_no        Char(20) dim(999);
        // End-DS;
      // RECEIVED data structure
        Dcl-DS dsResult  qualified;
          Dcl-DS dsParts  ;
            PartNumber     Char(20);
            AvailableQuantity Char(10);
            Price          Char(10);
            Message1       Char(256);
            Message2       Char(256);
          End-DS;
        End-DS;
      // External Procedures
        Dcl-PR QCMDEXC  ExtPgm('QCMDEXC');
          Cmd            Char(3000) Options(*varSize);
          CmdLen         Packed(15:5) Const;
          CmdDbcs        Char(3)    Const Options(*nopass);
        End-PR;
        // Initialization
        wTime_Called      = %timestamp();
        wRcd_Type         = '*Entry';
        wAccess_Key       = #job_number + %char(%TIMESTAMP());
        exsr log_Alert;
        exsr Initialize;
         exec sql  set option closqlcsr = *endmod,
                              commit    = *none,
                              datfmt    = *ISO,
                              datsep    = '-',
                              timfmt    = *ISO,
                              naming    = *SYS,
                              alwcpydta = *yes;
        clear Request;
        clear Result;
        request = '{'
                + wQQ
                + wQQ
                + '", "AuthKey" : '
                + ', "Parts": ['
                + wQQ
                + wQQ
        // create the json
        // DATA-INTO  Request %data(dsRequest) %gen('YAJLDTAGEN');
        wTime_SAP_Called = %timestamp();
        wRcd_Type        = '*SAP Called';
        exsr Log_Alert;
        wTime_SAP_Responded = %timestamp();
        wRcd_Type         = '*SAP Responded';
        exsr Log_Alert;
        // parse out the response
        wScan_Found_at = 0;
        wScan_Found_at = %scan('PartNumber':response:1);
        if wScan_Found_at <> 0;
          Exsr Parse_response;
          pQuantityAvailable = 'N/A';
        wRcd_Type = '*Exit';
        Exsr Log_Alert;
        Return;  // *inlr = *on;
        // Parse_Result into fields
        begsr Parse_Response;
        // find the part number
        wScan_Found_at = %scan(':"':response:wScan_Found_at:wScan_Found_at);
        wField_Start   = wScan_Found_at + 2;
        wScan_Found_at = %scan('",':Response:wField_Start);
        wField_end     = wScan_Found_at - 1;
        wPart_No       = %subst(response : wField_Start :
                               (wField_end - wField_Start + 1 ));
        // find the quantity
        wScan_Found_at = 0;
        wScan_Found_at = %scan('AvailableQuantity":':response:1);
           wField_Start   = wScan_Found_at + 19;
           wScan_Found_at = %scan(',' : Response : wField_Start );
           wQuantity_in   = %subst(response :
                                   wField_Start :
           if %subst(wQuantity_in:1:8) = '-99999.0';
              wQuantity          = %Int(wQuantity_in);
              pQuantityAvailable = %char(wQuantity);
        // find message 1
        wScan_Found_at = 0;
        wScan_Found_at = %scan('Message1"",' : response:1);
        if wScan_Found_at = 0;                            // no message
           wMessage1 = '';
          wScan_Found_at = %scan('Message1":"' : response:1);
             wField_Start   = wScan_Found_at + 11;
             wScan_Found_at = %scan('"",' : Response : wField_Start );
             wMessage1      = %subst(response :
                                     wField_Start :
        // find message 2
        wScan_Found_at = 0;
        wScan_Found_at = %scan('Message2"",' : response:1);
           wMessage2 = '';
          wScan_Found_at = %scan('Message2":"' : response:1);
             wMessage2      = %subst(response :
                                     wField_Start :
            wMessage2          = 'N/A';
        // Find HTTP 400 and 500 Messages
        wScan_Found_at = 0;
        wScan_Found_at = %scan('ErrorMessage":null' : response:1);
           wMessage3 = '*None';
          wScan_Found_at = %scan('ErrorMessage":"' : response:1);
             wField_Start   = wScan_Found_at + 15;
             wScan_Found_at = %scan('"}' : Response : wField_Start );
             wMessage3      = %subst(response :
                                     wField_Start :
            // pQuantityAvailable = 'N/A';
        endsr;
        // Initialization and setup.
        begsr Initialize;
        // dsRequest.CustomerAccountNumber = '1000171';
        exec sql  Select  substr(refdat,1,7)
                    into  :dsRequest.CustomerAccountNumber
                    from  REFERP
                   where  REFCAT = 'SAP'
                     and  REFKEY = :pCustomer;
        if sqlcod <> 0;      // Record not found
           exec sql  insert into iclogp
                     (Vendor_drop_ship_code ,
                      PART_NO ,
                      RCVTIME ,
                      HTTPERROR ,
                      Alert_Sent,
                      Alert_Processed ,
                      RECORD_TYPE ,
                      QUANTITY_AVAILABLE ,
                      ACCESS_KEY ,
                      SND_SAP
               Values(:pCustomer ,
                      :pPart_No ,
                      Current Timestamp ,
                      'Customer record for VDS not found.',
                      '*Exit' ,
                      'N/A' ,
                      :wAccess_Key ,
                      :wTime_SAP_Called
        // dsRequest.dsParts.Part_no       = '924-125';
        dsRequest.Part_no       = pPart_No;
        // Retrieve Authorization code from REFERP.
        // dsRequest.AuthKey  = '"TESTENV"';
        exec sql  Select  trim(refdat)
                    into  :dsRequest.AuthKey
                    from  REFERP
                     and  REFKEY = 'AUTH_CODE';
        if sqlcod  = 0;      // Record found
          dsRequest.AuthKey = '"' + %trim(dsRequest.AuthKey) + '"';
        else;              // not found
                      PART_NO ,
                      RCVTIME ,
                      HTTPERROR,
                      RCD_TYPE ,
                      ACCESS_KEY
               Values(:pCustomer ,
                      :pPart_No ,
                      Current Timestamp ,
              'Authorization Code is invalid or does not exist in REFERP.',
                      '*Entry' ,
                      :wAccess_Key
        // Validate the part number
        exec sql  Select  count(*)
                    into  :wCount
                    from  DE100M
                   where  IZPN   = :pPart_no;
        if wCount  = 0;                                    // Item number is invalid
                      PART_NO ,
                      RCVTIME ,
                      HTTPERROR,
                      RCD_TYPE ,
                      ACCESS_KEY
               Values(:pCustomer ,
                      :pPart_No ,
                      :wTime_Called ,
                      'Invalid part number',
                      '*Exit' ,
                      'N/A' ,
                      :wAccess_Key
        // http_setAuth( HTTP_AUTH_BASIC: 'apikey':'"TESTENV"');
        http_setAuth( HTTP_AUTH_BASIC: 'apikey' : dsRequest.AuthKey );
        http_debug(*on: '/tmp/json_05-debug.txt');
        uri = 'http://xxxxx/wwwww/api/'
            + 'ProductPriceAndAvailability';
        url = 'http://xxxxx/wwwww/DormanOrderingLibrary/api/'
        endsr;
        // Log called in time
        begsr Log_Alert;
        Select;
          when wRcd_Type = '*Entry';
            exec sql  Insert into ICLOGP
                      (VDS, PART_NO, QUANTITY_AVAILABLE,
                       RCVTIME, RCV_SAP, RPY2CALLER, WSREQUEST,
                       WSRESPONSE, HTTPERROR, RCD_TYPE,
                       ALERT_SENT, ALERT_PROCESSED, ACCESS_KEY)
                      Values( :pCustomer
                            , :pPart_No
                            , :pQuantityAvailable
                            , :wTime_Called         -- receive time
                            , :wTime_SAP_Called     -- time called SAP
                            , :wTime_SAP_Responded    -- time replied to caller
                            , :request
                            , :response
                            , :wHTTP_ERROR          -- http error
                            , :wRcd_Type
                            , ''                    -- Alert sent
                            , ''                    -- Alert processed
                            , :wAccess_Key
          when wRcd_Type = '*Exit';
            exec sql  update  ICLOGP
                         set  RCD_TYPE           = :wRcd_Type,
                              RPY2CALLER         = Current Timestamp ,
                              Quantity_Available = :pQuantityAvailable
                       where  ACCESS_KEY = :wAccess_Key;
          when wRcd_Type = '*SAP Called';
                              SND_SAP   = Current Timestamp ,
                              WSREQUEST = :Request
          when wRcd_Type = '*SAP Responded';
                         set  RCD_TYPE   = :wRcd_Type ,
                              RCV_SAP    = :wTime_SAP_Responded ,
                              WSRESPONSE = :Response
          other;
        endsl;
        endsr; // Log_Alert
ICIFC Logging - Copy.pdf
(130.47 KiB) Downloaded 4063 times
assignment400
I have attached a copy of the program.
Thank you.
Can you please edit the post to put code tags around the source so it is readable.
i.e. the word code in square brackets [ ] use /code to end it.
    That will    produce correctly   spaced results like this    ssss
assignment400
@jonboy49 - I am not sure I understand what you are requesting. Can you give an example? Thanks
I did! Look at what I said.
Here's a small extract of your source (with spacing added) wrapped in code tags
   pCustomer char(3);
   pPart_no char(15);
Either add them manually or just highlight the whole text and press the 5th from the left formatting button - the one with </> on it.
You will probably have to paste in your original code as all spacing has already gone. Assuming you do indent your code of course <grin>
I added the code tags for you, this time.
In the future, please post code like this (in the forum message editor):
[code]
/endif
... etc ... rest of code here ...
[/code]
Placing [code] before the pasted code and [/code] after it will mark it in the forums as code, so it will retain it's spacing and be much easier to read.
To get more detail on what is happening, please use HTTPAPI's performance tracing.
To do that, code this near the start of the program:
HTTP_setDebugLevel(2);
HTTP_Debug(*ON: '/tmp/assignment400_log.txt');
When you run your HTTP requests and reproduce the problem, a plethora of data should be logged to that IFS file, with timestamps indicating how long everything took. If you can send me a sample log showing the typical 3 second delay, I can interpret it to find out what HTTPAPI is doing during the time spent.
Be sure to remove any private information (including authorization: headers) prior to posting it publicly.
