Why am I getting this error with DATA-GEN?
DATA-GEN REQDS %data(REQUEST) %gen('YAJLDTAGEN');
RNX0355 - The program or the procedure in the service program was not found.
Cause . . . . . : An RPG procedure attempted to use program or procedure
'YAJLDTAGEN' for the DATA-GEN operation. The program or procedure is not
available for reason code 1.
Technical description . . . . . . . . : Reason codes and their meanings are
as follows:
1. The program or the procedure in the service program was not found.
Paul
DATA-GEN encountering RNX0355 error
Re: DATA-GEN encountering RNX0355 error
Is the YAJLDTAGEN program on your system? Is it in your library list? How about the service programs YAJLR4 and YAJL, are they there and in your library list?
None of the program and service programs are on the system. How do I get them installed?
I see where the download is now ... YAJL.zip.
but is the program YAJLDTAGEN also in YAJL.zip?
Inside that ZIP file is an IBMi save file called YAJLLIB72.savf -- if you restore that to your IBM i it will contain all of the YAJL tools.
Read the README.txt file inside that ZIP file for details.
