XML-INTO XML parser detected error code 2.
onie
Post by onie »
The <limits> tag can have 0 to many entries. I set up an array data structure with 10 elements.
 Dcl-ds limits Dim(10) qualified;
        hours             char(3);
        limit             char(4);
        limitid           char(5);
        minHours          char(3);
    End-Ds;
   XML-INTO limits  %XML(xmlData : 'doc=string case=any +
        allowmissing=yes allowextra=yes trim=all  +
        path=result//limits');
I have tried trim=none, trim=all and also excluded trim completely from the xml-into. I have used varchar and char for the data structure fields. These made no change to the error I get on this line of code. The 2 elements load to the array just fine, but then I get this error:
  Message Type . . . . . . . . . . . . . :   RNX
  Additional Message Info  . . . . . . . :   0351
  Message Data . . . . . . . . . . . . . :
               The XML parser detected error code 2.
XML limits data:
<limits>
<hours>0</hours>
<limit>250</limit>
<limitId>DSL</limitId>
<minHours>0</minHours>
</limits>
<limits>
<hours>0</hours>
<limit>250</limit>
<limitId>USLD</limitId>
<minHours>99</minHours>
</limits>
Or the complete XML data:
<?xml version='1.0' encoding='UTF-8'?><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"><soapenv:Body><ns5
:getCardResponse xmlns:ns5="http://xxxxxxxxxxxxxxx"><result><cardNumber>7083052034842200011</cardNumber><header><companyXRef><
/companyXRef><handEnter>POLICY</handEnter><infoSource>BOTH</infoSource><limitSource>POLICY</limitSource><locationOverride>0</locatio
nOverride><locationSource>POLICY</locationSource><overrideAllLocations>false</overrideAllLocations><originalStatus xmlns:xsi="http:/
/www.w3.org/2001/XMLSchema-instance" xsi:nil="1" /><payrollStatus>FOLLOWS</payrollStatus><override>0</override><policyNumber>1</poli
cyNumber><status>ACTIVE</status><timeSource>BOTH</timeSource><lastUsedDate xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi
:nil="1" /><lastTransaction>0</lastTransaction><payrollUse>N</payrollUse><payrollAtm>DISALLOW</payrollAtm><payrollChk>DISALLOW</payr
ollChk><payrollAch>DISALLOW</payrollAch><payrollWire>DISALLOW</payrollWire><payrollDebit>DISALLOW</payrollDebit></header><infos><inf
oId>DRID</infoId><lengthCheck>false</lengthCheck><matchValue>999999</matchValue><maximum>0</maximum><minimum>0</minimum><reportValue
></reportValue><validationType>EXACT_MATCH</validationType><value>0</value></infos><limits><hours>0</hours><limit>250</limit><limitI
d>DSL</limitId><minHours>0</minHours></limits><limits><hours>0</hours><limit>250</limit><limitId>USLD</limitId><minHours>99</minHour
s></limits><locationGroups>1</locationGroups></result></ns5:getCardResponse></soapenv:Body></soapenv:Envelope>
Just the limits:
s></limits>
Re: XML-INTO XML parser detected error code 2.
Well there are errors in the XML you posted so it is difficult to tell where the problem may lie.
Are you sure anything gets loaded - with the path you show I wouldn't expect it to find anything, The error message you received also included information on where the error was detected. You haven't shown us that.
Things like trim and changes in the data type will have zero impact on this kind of error. I suspect the path is the real problem.
The XML looks okay to me, aside from some extra linefeeds (that were probably an artifact of the way it was copy/pasted)
Here it is reformatted:
<soapenv:Envelope
    <soapenv:Body>
        <ns5:getCardResponse
            <result>
                <header>
                    <companyXRef></companyXRef>
                    <locationOverride>0</locationOverride>
                    <originalStatus
                        xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="1" />
                        <policyNumber>1</policyNumber>
                        <lastUsedDate
                            <payrollChk>DISALLOW</payrollChk>
                        </header>
                        <infos>
                            <infoId>DRID</infoId>
                            <reportValue></reportValue>
                            <value>0</value>
                        </infos>
                        <limits>
                            <hours>0</hours>
                            <limit>250</limit>
                        </limits>
                        <limits>
                            <hours>0</hours>
                            <limit>250</limit>
                        </limits>
                    </result>
            </soapenv:Body>
        </soapenv:Envelope>
The problem (maybe this was what Jon was saying?) is the path. Your path doesn't include all of the XML elements it needs to get to the "limits" tag. Notice the outermost element of your document is soapenv:Envelope, but for some reason your path starts at "result".
To try it out, I copy/pasted your XML document into a file in my IFS, and changed your code to read from a file. Then modified the path and added some code to display some results -- this worked for me:
  dcl-ds PSDS qualified PSDS;
    count             int(20) pos(372);
    hours             char(3);
    limit             char(4);
    limitid           char(5);
    minHours          char(3);
  End-Ds;
  dcl-s xmlData       varchar(100) inz('onie.xml');
  dcl-s msg           varchar(52);
  dcl-s x             int(10);
  XML-INTO limits  %XML(xmlData : 'doc=file case=any +
      allowextra=yes allowmissing=yes trim=all  +
      path=soapenv:Envelope/soapenv:Body/ns5:getCardResponse+
      /result/limits');
  for x = 1 to PSDS.count;
    msg = 'hours=' + %trim(limits(x).hours)
        + ' limit=' + %trim(limits(x).limit)
        + ' limitid=' + %trim(limits(x).limitid)
        + ' minHours=' + %trim(limits(x).minHours);
    dsply msg;
  endfor;
Having said that, here are some things I'd do differently:
  1. I never use case=any, I would change it to case=convert -- even though that's not strictly needed here, it's a good habit to get into.
  2. The allowmissing=yes and allowextra=yes don't seem to serve any purpose in your case, and are making this program harder to debug. I would remove them.
  3. When working with documents that have namespaces (including SOAP documents like this one) I would recommend stripping off the namespaces, because they aren't guaranteed to always be the same. For example, this time they used "soapenv" as the namespace for SOAP elements, but in the future they could change it to "soap" or "env" or "bobsYourUncle" -- and they'd expect your program to still work provided that the namespace they use points to the same URL. IBM provides the option ns=remove for this purpose.
  4. trim=all is the default, so no need to supply it.
So with those changes, this is what my test program would look like:
    hours             char(3);
    limit             char(4);
    limitid           char(5);
    minHours          char(3);
  End-Ds;
  dcl-s x             int(10);
  XML-INTO limits  %XML(xmlData : 'doc=file case=convert ns=remove +
      path=Envelope/Body/getCardResponse/result/limits');
    dsply msg;
  endfor;
Obviously, you'll need to change it back to doc=string if your XML is in the string vs. in a file. But, hopefully this gets you pointed in the right direction.
Scott Klement wrote: Thu Dec 01, 2022 7:12 pm The problem (maybe this was what Jon was saying?) is the path. Your path doesn't include all of the XML elements it needs to get to the "limits" tag. Notice the outermost element of your document is soapenv:Envelope, but for some reason your path starts at "result".
Yup that was what I was saying. I don't know if the OP edited the post or if there was a "burp" in the software when it displayed the original message to me because there were no code tags in place when I saw the post and there were bits missing/added to the XML. I copied/pasted it and tried to format it as you did but the formatter just barfed.
I added the code tags because it was hard to read... Maybe that fixed the XML formatting problem, too.
onie
Post by onie »
CTL-OPT DFTACTGRP(*NO) ACTGRP('TMTILE')
      BNDDIR('AVRTBNDDIR' :'HTTPAPI');
     CTL-OPT OPTION(*DEBUGIO:*SRCSTMT) DEBUG FIXNBR(*ZONED) EXTBININT(*YES)
       INDENT('|') USRPRF(*OWNER) MAIN(Main);
     DCL-F EFSTSERVER DISK(*EXT) USAGE(*INPUT:*UPDATE) KEYED;
   // Program Interface and Prototypes                               //
   // Have lib LIBHTTP in lib list.
     /include HTTPAPI_H
     /Copy LIBHTTP/QRPGLESRC,IFSIO_H
   //--Move *DIAG and Re-Send *ESCAPE Messages-----------------------//
   Dcl-Pr ForwardMessage ExtProc('ERR03');
   End-Pr;
   DCL-PR OpenFile pointer extproc('_C_IFS_fopen');
      *n pointer value;  //File name
       *n pointer value;  //File mode
   END-PR;
   // This API's will pull data by CRLF characters
   DCL-PR ReadFile pointer extproc('_C_IFS_fgets');
      *n pointer value;  //Retrieved data
      *n int(10) value;  //Data size
      *n pointer value;  //Misc pointer
   END-PR;
   DCL-PR CloseFile extproc('_C_IFS_fclose');
   END-PR;
   // Global Constants, Data Structures, and Variables               //
    Dcl-C FAULT Const('path=soapenv:Envelope/soapenv:Body/soapenv:+
         Fault/faultstring doc=file');
    //--EFS Web Services log Directory path -------------------------//
    Dcl-C IFSPATH Const('/efs/webservices/log');
    // 2022-11-11T06:59:17.000-06:00  serverTime return value
    Dcl-C TIMEOUT       Const(10);
    Dcl-S URL           VarChar(100) Inz(*blanks);
    Dcl-S DebugFlag     Ind          Inz(*On);
    Dcl-S ErrorMessage  Char(80)     Inz(*Blanks);
    Dcl-S ErrorMessage2 Char(80)    Inz(*Blanks);
    Dcl-S #msg          Char(300)    Inz(*Blanks);
    Dcl-s $I_ClientId   Char(32)     Inz(*Blanks);           // Client ID
    Dcl-s $I_Card#      Char(25) Inz('7083052034842200011'); // EFS Card Number
    Dcl-S SOAP        VarChar(1000) Inz(*Blanks);
    Dcl-S SOAPAddr    Pointer       Inz(*Null);
    Dcl-S SOAPLen     Int(10)       Inz(*Zeros);
    Dcl-S Filepath    VarChar(100)  Inz(*Blanks);
    Dcl-S Debugpath   VarChar(100)  Inz(*Blanks);
    Dcl-S RC          Int(10)       Inz(*Zeros);
    Dcl-S FaultString VarChar(300)  Inz(*Blanks);
    Dcl-s cardNumber     char(25)   Inz(*Blanks);
    Dcl-s POS            int(5);
    Dcl-s locationGroups     char(10);
        Data structures all load with no problem, util it gets to limits DS.
    Dcl-DS header qualified;
        companyXRef       char(15);  //The Company Xref populated for the card
        handEnter         char(6);   //ALLOW, DISALLOW OR POLICY
        infoSource        char(6);   //INFOS AT LEVEL: POLICY, CARD OR BOTH
        limitSource       char(6);   //POLICY, CARD OR BOTH
        locationOverride  char(1);   //Boolean 0=no override  1=override
        locationSource    char(6);   //POLICY, CARD OR BOTH
        overrideAllLocations char(6);   //POLICY, CARD OR BOTH
        originalStatus    char(8);   // ?
        payrollStatus     char(8);   //ACTIVE, INACTIVE OR FOLLOWS
        override          char(1);   //BOOLEAN 0=FALSE 1=TRUE
        policyNumber      char(3);   //POLICY# CARD BELONGS TO, 1-99
        status            char(8);   //ACTIVE,INACTIVE,HOLD OR DELETE
        timeSource        char(6);   //POLICY, CARD OR BOTH
        lastUsedDate      char(29);  //THE LAST USED DATE/TIME ON CARD
        lastTransaction   char(29);  //AUTHORIZATIO# OF LAST TRANSACTION ON CARD
        payrollUse        char(1);   //P-PAYROLL,B-PAYROLL/NORMAL,N-NORMAL,Y-DEBIT,L-DEBIT LIMIT
        payrollAtm        char(8);   //DISALLOW OR ALLOW SMART FUNDS FROM ATM
        payrollChk        char(8);   //DISALLOW OR ALLOW REGISTERED CHECK SMART FUNDS
        payrollAch        char(8);   //DISALLOW OR ALLOW ACH SMART FUNDS
        payrollWire       char(8);   //DISALLOW OR ALLOW WIRES SMART FUNDS
        payrollDebit      char(8);   //DISALLOW OR ALLOW SMART FUNDS DEBIT NETWORK
    End-ds;
    Dcl-ds infos qualified;
        infold            char(4);   //INFO ID
        lengthCheck       char(5);   //IF LENGTH CHECK IS ON. TRUE/FALSE
        matchValue        char(24);  //MATCH OF DRIVER ID#, UNIT# ect.
        maximum           char(10);  //MAXIMUM VALUE IF LENGTH CHECK IS TRUE
        minimum           char(10);  //MINIMUM VALUE IF LENGTH CHECK IS TRUE
        reportValue       char(24);  //IF REPORT ONLY, THIS IS THE VALUE
        validationType    char(13);  //VALIDATION TYPE FOR THE PROMPT
        value             char(1);   //ODOMETER, HUBOMETER OR 0
    End-ds;
        hours             char(3);
        limit             char(4);
        limitid           char(5);
        minHours          char(3);
    End-Ds;
    //--Program Status Data Structure---------------------------------//
    Dcl-Ds *N psds;
      PgmNme    Char(10)   Pos(1);           // PGM name
      ErrMsg    Char(80)   Pos(91);          // Error text
      JobNme    Char(10)   Pos(244);         // Job name
      UsrNme    Char(10)   Pos(254);         // User name
      JobNum    Zoned(6:0) Pos(264);         // Job number
      Parser    Zoned(5:0) Pos(368);         // Parser error
      XMLCount  int  (20)  POS(372);         // Element count
    End-Ds;
    // Main Procedure                                                 //
    Dcl-Proc Main;
      //**Procedure Body**********************************************//
      Monitor;
     //--Set Request Variables to Default Values-------------------//
        Reset URL;
        Reset SOAP;
        Reset SOAPAddr;
        Reset SOAPLen;
        Reset DebugFlag;
        Reset FaultString;
        Reset ErrorMessage;
        Reset #MSG;
        chain(n) (1) efstserver;  // 1=Active Server
        if %found(efstserver);
          $I_ClientID = ClientID;
          URL = %trim(DOMAIN);
       //--Set Filepaths for IFS Files-------------------------------//
        Reset Filepath;
        Filepath = IFSPATH + '/' +
          %EditC(%Dec(%TimeStamp):'X') + '_' +
          %EditC(JobNum:'X')           + '_' +
          %Trim(UsrNme)                + '_' +
          'getCard.XML';
        Reset DebugPath;
        If DebugFlag;
          DebugPath = IFSPATH + '/' +
            'getCard.TXT';
           http_debug(*On:DebugPath);
           EndIf;
        SOAP =
           '<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap' +
             '.org/soap/envelope/" xmlns:com="http://com.xxx.xxxx.xxxxxx">' +
             '<soapenv:Header/>' +
             '<soapenv:Body>' +
               '<com:getCard>' +
                 '<clientId>' + %Trim($I_ClientID) + '</clientId>' +
                 '<cardNumber>' + %Trim($I_Card#) + '</cardNumber>' +
               '</com:getCard>' +
             '</soapenv:Body>' +
           '</soapenv:Envelope>';
        SOAPAddr = %Addr(SOAP) + 2;
        SOAPLen = %Len(%Trim(SOAP));
        //--Run EFS Web Service---------------------------------------//
        RC = HTTP_POST(URL:SOAPAddr:SOAPLen:FILEPATH:TIMEOUT);
     IF Rc = 1;  //  Successful
       processData();
      XML-Into FaultString %XML(Filepath:FAULT);
        ErrorMessage = %Trim(FaultString);
        ErrorMessage2 = %trim(http_error());
        #MSG = (Errormessage + ' ' + Errormessage2);
        sendMsg(#MSG);
         Dump(A);
         Return;
    On-Error;
      forwardMessage();
      Dump(A);
    EndMon;
      Return;
    End-Proc;
   Dcl-Proc ProcessData;  -----------------------------------  Here I read the IFS file and strip the front of the file off, so it starts at <result>.
       DCL-S FilePtr pointer inz;
       DCL-S PathFile char(100);
       DCL-S OpenMode char(5);
       Dcl-s RtvData char(10000);
       Dcl-s xmlData char(10000);
      Monitor;
     // Null terminate lines with x'00' for API's
     PathFile = %Trim(Filepath) + x'00';
     OpenMode = 'r' + x'00';
     FilePtr = OpenFile(%addr(PathFile):%addr(OpenMode));
     if (FilePtr = *null);
        Dump(A);
        Return;
      // RtvDta should contain each row up to the CR/LF mark.
    dow (ReadFile(%addr(RtvData):32767:FilePtr) <> *null);
         RtvData = %xlate(x'00':' ':RtvData);  // *NULL
         RtvData = %xlate(x'25':' ':RtvData);  // LF
         RtvData = %xlate(x'0D':' ':RtvData);  // CR
    Monitor;
       POS = %SCAN('<result>' : RtvData);
       xmlData = %subst(RtvData:POS);
     // Card Number  ------------------------------------------------------------------- carNumber loads just fine.
     XML-INTO cardNumber  %XML(xmlData : 'doc=string case=any +
          allowextra=yes allowmissing=yes trim=none +
          path=result/cardNumber');
      dsply cardNumber;
     //Load header data structure ----------------------------------------------------- Header DS loads just fine.
     XML-INTO header  %XML(xmlData : 'doc=string case=any +
          path=result/header');
     //Load infos data structure  --------------------------------------------------------Infos DS loads just fine.
     XML-INTO infos  %XML(xmlData : 'doc=string case=any +
          path=result/infos');
     //Load limits data structure
     XML-INTO limits  %XML(xmlData : 'doc=string case=convert +  -------------<-   RNX0351 Parsing error code 2 when it hits this line.
       path=result/limits');  ----------------------------------------------------------------  But it does load the 2 elements sent. If I change
       --------------------------------------------------------------------------------------------Dim(2) I get NO error instead of Dim(10) that gets an error.
     //Load Location Groups
     XML-INTO locationGroups  %XML(xmlData : 'doc=string case=any +  ---------This loaded when I changed the above array to Dim(2).
          path=result/locationGroups');
      dsply locationGroups;
     On-Error;
        Dump(A);
        CloseFile(%addr(PathFile));
        sendMsg(ErrMsg);
        Return;
     EndMon;
      enddo;
      On-Error;
       ForwardMessage();
    EndMon;
    Return;
    End-Proc;
I strip off the xml so that the string I am working with starts at the <result> tag.
:getCardResponse xmlns:ns5="http://xx.xx.xxx.com">
<result>
<header>
<originalStatus xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="1" />
<lastUsedDate xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="1" />
</header><infos>
<value>0</value>
</infos>
<limits>  ----------------------------------------------------- This is defined as a DIM(10), but it only has 2 elements in this data received. In debug
<hours>0</hours> ------------------------------------------these load to the array and then it blows up with, The XML parser detected error code 2.
<limit>250</limit>
<limitId>
DSL</limitId>
</limits>
<limits>
<hours>0</hours>
<limit>250</limit>
</limits>
      EVAL limits   ---------------------------- When I changed the array to DIM(2) NO parsing error code 2.
 LIMITS.HOURS(1) = '0  '   ------------------- If there are blank array elements then it has an error.
 LIMITS.LIMIT(1) = '250 '
 LIMITS.LIMITID(1) = 'DSL  '
 LIMITS.MINHOURS(1) = '0  '
 LIMITS.COUNT_HOURS(1) = 1
 LIMITS.HOURS(2) = '0  '
 LIMITS.LIMIT(2) = '250 '
 LIMITS.LIMITID(2) = 'USLD '
 LIMITS.MINHOURS(2) = '99 '
 LIMITS.COUNT_HOURS(2) = 1
onie
Post by onie »
I see your code worked with the loading of the array. I will try again and see if I can get it to work.
I was about to try to learn how to do a %handler procedure.
Thank you very much for you example code.
Onie
onie
Post by onie »
I am wondering if the way the read is bringing the data?
Dump(A);
Return;
This is how I was told to bring the file into the program.
Could this cause a problem for the xml-into?
Onie
onie
Post by onie »
EVAL limits
 LIMITS.HOURS(3) = '   '
 LIMITS.LIMIT(3) = '    '
 LIMITS.LIMITID(3) = '
 LIMITS.MINHOURS(3) = '   '
 LIMITS.HOURS(4) = '   '
        Dump(A);
        Return;
   // dow (ReadFile(%addr(RtvData):32767:FilePtr) <> *null);
   //      RtvData = %xlate(x'00':' ':RtvData);  // *NULL
   //      RtvData = %xlate(x'25':' ':RtvData);  // LF
   //      RtvData = %xlate(x'0D':' ':RtvData);  // CR
   ReadFile(%addr(RtvData):10000:FilePtr);               I changed to not do the %xlate on the read, but still get the same error.
