gsk_env_init: (GSKit) Storage allocation request failed.
AnthonyO
Post by AnthonyO »
Hi all,
Been using HTTPAPI for years, thank you!
We are currently on version 1.39.
Every so often we receive the following error when posting to endpoints, and we are trying to track down the root of the error.
Some of our jobs are continually running, and we're wondering if something didn't close down properly when ssl connection issues arise.
When our error occurs, we've noticed we've also received prior errors in the job:
SSL Handshake: (GSKit) Peer not recognized or badly formatted message received.
SSL Handshake: (GSKit) I/O: A connection with a remote socket was reset by that
Has anyone experienced anything similar?
We're looking at some of the source code "COMMSSLR4", and we noticed we only issue a "gsk_secure_soc_close" after a timeout from a "gsk_secure_soc_init".
We are wondering if that it always should be issued if there were any errors during a "gsk_secure_soc_init"? Our thought here is that we may have some half baked work still in memory.
0410.00  c                   eval      rc = gsk_secure_soc_init(wwSslh)
0411.00  c                   if        rc <> GSK_OK
0412.00  c                   if        rc = GSK_IBMI_ERROR_TIMED_OUT
0413.00  c                   callp     SetError(HTTP_SSTIMO: 'Time out during '
0414.00  c                               'SSL handshake')
0415.00  c                   callp     gsk_secure_soc_close(wwsslh)
0416.00  c                   return    *OFF
0417.00  c                   endif
0418.00  c                   callp     SetError(HTTP_SSSNFD: 'SSL Handshake: '
0419.00  c                               ssl_error(rc))
0420.00  c                   return    *OFF
0421.00  c                   endif
Thanks!
Re: gsk_env_init: (GSKit) Storage allocation request failed.
Yes, anytime it returns *OFF from CommSSL_Upgrade, it should be cleaning up the socket with gsk_secure_soc_close().
So, that does sound like a possible bug... it should look more like this:
c                   if        rc <> GSK_OK
c                   callp     SetError(HTTP_SSTIMO: 'Time out during '+
c                               'SSL handshake')
c                   return    *OFF
c                   endif
c                   callp     SetError(HTTP_SSSNFD: 'SSL Handshake: ' +
c                               ssl_error(rc))
c                   return    *OFF
c                   endif
AnthonyO
Post by AnthonyO »
Thank you for checking Scott.
How often do you make new releases? We're wondering if we should wait for a new release, or make a change to the source code ourselves. What would you recommend? Thanks.
I make new releases when I find a need to make one... there's no schedule, its just done when needed.
Seems like the change is trivial, why not just make it?
AnthonyO
Post by AnthonyO »
Seems trivial enough. Thanks!
We are using the standard default libhttp. Can you post the correct compile statement for COMMSSLR4?
You can just run the INSTALL program, it will compile everything.
