Consuming a REST Web Service
sLucke1015
This will be my first experience accessing an API...
It is stipulated that the request be accompanied by a header that looks like this:
‘Authorization: Basic XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX’ where the repeating “X” is a hashed representative of the API User and Password.
I am now attempting to create an RPG program to send the request via HTTPAPI or SQL.
I have been able to create the necessary authentication string above and using Insomnia send a GET request and receive a valid response using NO AUTH and the above header
The website is https://...
The request is for all documents.
For “Auth” I have checked “No Authentication”.
Instead, I have a Header with Key = “Authorization”, and “Value = Basic “ concatenated with the long string we put together before using the apiKey and apiPin.
The test response should a JSON table with four records with five fields each. Of course when this goes live the responses will vary.
Thank you for any help!
Re: Consuming a REST Web Service
HTTPAPI can create it for you. Just do this before making the request:
HTTPAPI will calculate the value and send it as an authorization basic header -- according to the rules for basic. (FWIW, the string it uses isn't actually hashed -- it is just base64-encoded -- that's how basic auth works.)
If it's important to create your own, you can do that too -- but it really shouldnt be necessary for something this simple.
http_setAuth(HTTP_AUTH_BASIC: 'userid here': 'password here');If it's important to create your own, you can do that too -- but it really shouldnt be necessary for something this simple.
sLucke1015
HI Scott,
I'm sorry in the initial post I said "User" and Password" when I should have said "APIKEY" and "APIPIN".
I don't know if that makes a difference or not but I have made some progress in that I seem to be getting in to the API server but am not getting what I expect to get.
Thank you very much for your time,
Scott
I also neglected to say that we were given this documentation regarding how to get in:
Security Documentation
All api calls require and apikey and an api hash.
Each affiliate will be assigned a unique apikey and api pin for each county.
The api hash will be build by hashing a random seed value. The concept is outlined below.
Please note this code is just conceptual and not actual implementation.
var seed = generateRandomValue();
var prehash = apikey + seed + apipin;
var apihash = 's2/'+ seed + '/' + encodeHex(sha256(prehash));
var authKey = base64Encode(apikey + ':' + apihash);
Authentication will be included as a basic auth http header with each call.
It will be sent as a base64 encoded representation of the following: apiKey:apiHash
Sample Request
--header 'Authorization: Basic X1JkelZxNEN3NlRRSnk2WDNGZzQ1bjUyU0k3OE03ZGU6czIvWGY3VUk4NDAzNGtodnBLYi84YjZhNGRkOTNlN2M2ZTg1Y2ZlMjE0MGRiNzJlNDQzYjI0YjgyN2QwMDY2OWQ0NTI2YTZkZjcwNzU0OWE5M2Fl'
Below is the code that I have been using and below that are the results that I am expecting to receive.
http_debug(*ON);
url = 'https://staging.iowalandrecords.org/esu ... /api/read-
yForDownload';
authorizationToken = 'Basic ' + hashedAPIkey();
: %paddr(addSpecialHeaders)
: %addr(authorizationToken) );
httpResponse = HTTP_req( 'GET' : url : *omit : resultString );
Data-Into docsReady
%data( resultString : 'case=any countPrefix=num_ allowExtra=yes' )
%parser( 'YAJL/YAJLINTO' );
result = *ON;
result = *OFF;
endMON;
dump;
https_cleanup();
*inlr = *ON;
Desired results
"groupID": 86559,
"groupName": "HUMBOLDT GROUP 2",
"recorderApprovedDate": "2019-05-21 19:40:50.471",
"sequence": 1,
"priaDocObjectID": 100470
"groupID": 86559,
"sequence": 2,
"priaDocObjectID": 100469
"groupID": 86559,
"sequence": 3,
"priaDocObjectID": 100468
"groupID": 86559,
"sequence": 4,
"priaDocObjectID": 100471
httpapi_debug.txt
OS/400 Ver V7R3M0
DNS resolver retry : 2
DNS default domain: GMDSOLUTIONS.LOCAL
DNS server found: 10.100.101.5
DNS server found: 10.100.101.6
DNS server found: 8.8.8.8
https_init(): entered
QSSLPCL = *TLSV1.2 *TLSV1.1 *TLSV1 *SSLV3
initializing GSK environment
GSK Environment now available
SNI hostname set to: staging.iowalandrecords.org
Cert Validation Code = 6000
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
Serial Number: 06:D0:D3:8B:F0:A1:E6:A1:10:9C:EB:55:36:84:19:70
Common Name: staging.iowalandrecords.org
Country: US
State/Province: Iowa
Locality: Johnston
Org Unit: Electronic Services System
Issuer CN: DigiCert SHA2 Extended Validation Server CA
Issuer Country: US
Issuer Org: DigiCert Inc
Issuer Org Unit: www.digicert.com
Version: 3
not before: 20230130180000
Unknown Field: 18:00:00 30-01-2023
not after: 20240302175959
Unknown Field: 17:59:59 02-03-2024
Unknown Field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
Unknown Field: 2048
Unknown Field: BB6E45C8F07ABFEE36A2B571014DF81F
Unknown Field: 8812F39CEA90589B8DB357AC33AA3FFA583CA30B
Unknown Field: 43E538FA65CDA4CBC9123C7CBD57BB0FB7A56D74ADF5A4B0C432408EE1E5B45A
Unknown Field: 5
Unknown Field: staging.iowalandrecords.org
Unknown Field: 0
Unknown Field: 2.23.140.1.1
Unknown Field: 2.16.840.1.114412.2.1
Unknown Field: http://ocsp.digicert.com
do_oper(GET): entered
GET /esubmission/services/county/api/readyForDownload HTTP/1.1
Host: staging.iowalandrecords.org
User-Agent: http-api/1.45
authorization: Basic X2pZZUJWbjJOZTRwUzFKc2w5eDNROTQ0ZVlUYmViM2M6czIvTnpwVEVHaVBwV1lsLzBiZWRlZT
HTTP/1.1 408 Request Timeout
Date: Fri, 10 Mar 2023 20:05:03 GMT
Server: Apache
Strict-Transport-Security: max-age=15768000; includeSubDomains; preload
X-Frame-Options: SAMEORIGIN
Content-Length: 221
Connection: close
Content-Type: text/html; charset=iso-8859-1
SetError() #13: HTTP/1.1 408 Request Timeout
recvresp(): end with 408
recvdoc parms: identity 221
recvdoc(): Receiving 221 bytes.
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>408 Request Timeout</title>
</head><body>
<h1>Request Timeout</h1>
<p>Server timeout waiting for the HTTP request from the client.</p>
</body></html>
CONTINUED
I made an attempt to use your suggestion just now and here is what the code and log file look like"
CODE
http_debug(*ON);
yForDownload';
http_setAuth(HTTP_AUTH_BASIC: apiKey: apiPin);
Data-Into docsReady
result = *ON;
result = *OFF;
endMON;
https_cleanup();
*inlr = *ON;
httpapi_debug.txt
OS/400 Ver V7R3M0
http_setauth(): entered
Country: US
Locality: Johnston
Issuer Country: US
Version: 3
Unknown Field: 2048
Unknown Field: 5
Unknown Field: 0
Authorization: Basic X2pZZUJWbjJOZTRwUzFKc2w5eDNROTQ0ZVlUYmViM2M6NDI0MDcxMTQ0ODg1MTI0MzkxNw==
HTTP/1.1 401 401
Date: Fri, 10 Mar 2023 19:37:52 GMT
Server: Apache
WWW-Authenticate: Basic realm="Realm"
X-XSS-Protection: 1; mode=block
Cache-Control: no-cache, no-store, max-age=0, must-revalidate
Pragma: no-cache
Expires: 0
Strict-Transport-Security: max-age=31536000 ; includeSubDomains
X-Frame-Options: DENY
Content-Type: application/json;charset=UTF-8
Content-Length: 26
SetError() #13: HTTP/1.1 401 401
recvresp(): end with 401
recvdoc parms: identity 26
interpret_auth(): entered
SetError() #36: This page requires a user-id & password
AuthPlugin_mustReceiceAuthErrorPage(): entered
recvdoc(): Receiving 26 bytes.
{"error": "Access Denied"}
Scott
Sample Request
http_debug(*ON);
yForDownload';
Data-Into docsReady
result = *ON;
result = *OFF;
endMON;
dump;
https_cleanup();
*inlr = *ON;
Desired results
"groupID": 86559,
"sequence": 1,
"groupID": 86559,
"sequence": 2,
"groupID": 86559,
"sequence": 3,
"groupID": 86559,
"sequence": 4,
httpapi_debug.txt
OS/400 Ver V7R3M0
Country: US
Locality: Johnston
Issuer Country: US
Version: 3
Unknown Field: 2048
Unknown Field: 5
Unknown Field: 0
Server: Apache
Content-Length: 221
Connection: close
<html><head>
</head><body>
</body></html>
CONTINUED
CODE
http_debug(*ON);
yForDownload';
Data-Into docsReady
result = *ON;
result = *OFF;
endMON;
https_cleanup();
*inlr = *ON;
httpapi_debug.txt
OS/400 Ver V7R3M0
Country: US
Locality: Johnston
Issuer Country: US
Version: 3
Unknown Field: 2048
Unknown Field: 5
Unknown Field: 0
HTTP/1.1 401 401
Server: Apache
Pragma: no-cache
Expires: 0
Content-Length: 26
I haven't the time right now to go through your code, but I did notice that you don't seem to be setting the network CCSID for JSON data. In all of my JSON routines I have:
At the start of my code. Just after setting up debug.
I'm pretty sure it won't help your current situation, but when you do get connected, you'll need it to make sense of the data.
http_setOption ( 'network-ccsid' : '1208' );
sLucke1015
Thank you Jonboy49. It has been added to the program. Very much appreciate your input.
In your documentation you show this as the last step:
That is exactly what http_setauth does -- it combines the two parts (I call them userid/password rather than apikey and apihash, but they are the same). However, the code that comes before that line is custom to this API, and you will have to code it yourself.
So your code should look something like this:
and the hashedApiKey() routine should be responsible for generating the 'apihash' variable by performing these steps:
Also take care to ensure that you convert your data to UTF-8 prior to generating the hash. Otherwise, your hash will not match the one on the server (since it's unlikely that it's generating its hash from EBCDIC data.)
So the steps in RPG would be:
1) Generate a random seed.
2) Combine the apikey + seed + apipin.
3) Convert the output of step 2 to UTF-8.
4) Use the https://www.ibm.com/docs/api/v1/content ... 3calha.htm QC3CALHA system API (or equivalent) to generate a hash of the UTF-8 string.
5) Convert the hash to hex. (You can use the CVTHC MI-built-in for this if you want)
6) Concatenate s2/ + seed + the result of step 5 to create the apihash variable. (This should be in EBCDIC)
7) That apihash variable is what is placed in the 'password' parameter to http_setAuth.
HTTP_setAuth(HTTP_AUTH_BASIC: apiKey: hashedAPIkey());
sLucke1015
Thank you very much Scott.
It's working. The json string is being returned as expected.
Thanks again!
Thanks again!
sLucke1015
If a single RPGLE program is doing many "HTTP_req" and "HTTP_string" operations, will one "HTTP_setAuth" suffice?
...or will multiple be necessary?
The single one should be sufficient -- it will store in the credentials in memory and re-use them until you clear them (by calling HTTP_setAuth again with HTTP_AUTH_NONE) or until the activation group is reclaimed.
sLucke1015
I am now running into a problem with large documents with the following statement:
rc = HTTP_req( 'GET' : url : *omit : z_Buffer );
This is the DS that the incoming data will be placed into:
[/size]
I have the z_Buffer field set to VARCHAR(16773100) the max, but the large document data sometimes exceeds this, therefore the JSON is incomplete.
Or maybe I'm doing something else wrong...
Is there any way to access this so that the large amount of data can be retrieved?
Thanks again,
dcl-ds downloadDoc qualified; // -downloadDoc
dcl-ds requestGroup; // --requestGroup
dcl-ds submittingParty; // ---submittingParty
name varchar(35); // "testpayment"
num_contactDetailList packed(2:0);
dcl-ds contactDetailList dim(99); // ----contactDetailList
name varchar(35); // "Franklin, Ida"
num_contactPoint packed(2:0);
dcl-ds contactPoint dim(99); // -----contactPoint
roleType varchar(12); // "Work"
type varchar(12); // "Email"
value varchar(45); // "phil@clris.com"
end-ds; // -----contactPoint
end-ds; // ----contactDetailList
end-ds; // ---submittingParty
dcl-ds request; // ---request
num_key packed(2:0);
dcl-ds key dim(99); // ----key
name varchar(20); // "sequence"
value varchar(25); // "1"
end-ds; // ----key
dcl-ds priaRequest; // ----priaRequest
type varchar(12); // "Other"
typeOtherDescription varchar(25); // "ESubmission"
dcl-ds package; // -----package
dcl-ds priaDocument; // ------priaDocument
dcl-ds recordingEndorsement; // -------recordingEndorsement
numberOfParcels zoned(5:0); // 0
dcl-ds fees; // --------fees
num_fee packed(2:0);
dcl-ds fee dim(99); // ---------fee
description varchar(25); // "StandardFee" <-----<<<
amount zoned(7:2); // 5.00
end-ds; // ---------fee
totalAmount zoned(9:2); // 7.00
end-ds; // --------fees
num_exemptions packed(2:0);
dcl-ds exemptions dim(99); // --------exemptions
typeOtherDescription varchar(25); // "DeclarationOfValue"
end-ds; // --------exemptions
end-ds; // -------recordingEndorsement
countyOfRecordationName varchar(25); // "Humboldt"
num_embeddedFile packed(2:0);
dcl-ds embeddedFile dim(4); // -------embeddedFile
encodingType varchar(25); // "B64Encode"
mimeType varchar(10); // "TIFF"
name varchar(60); // "Recorde...Template.pdf"
numberOfPages zoned(4:0); // 1
sequenceIdentifier zoned(4:0); // 1
document varchar(300000); // ????????????????
end-ds; // -------embeddedFile
type varchar(20); // "Other"
typeOtherDescription varchar(70); // "CornerCertificates"
end-ds; // ------priaDocument
end-ds; // -----package
end-ds; // ----priaRequest
end-ds; // ---request
end-ds; // --requestGroup
end-ds; // -downloadDocI have the z_Buffer field set to VARCHAR(16773100) the max, but the large document data sometimes exceeds this, therefore the JSON is incomplete.
Thanks again,
