DATA-INTO when entire JSON Document is an array
kdanforth
Post by kdanforth »
I get the following response from an API call. I want to use DATA-INTO to parse it. I've used DATA-INTO with plenty of JSON responses in the past, but this is the first time when the entire document is an array. What would the data structure look like?
On a side note, I can't use "Rel" as a DS subfield as this is apparently a reserved word. I don't actually need the field so I've removed it from the DS and specified "allowmissing=yes" in the data options, but it would be good to know how to handle this in the future.
API Response:
"Rel": "detail",
"Href": "https://apisandbox.electioapp.com/consi ... 00-0C8-FJX"
Re: DATA-INTO when entire JSON Document is an array
Just code it as a DS array like so:
dcl-s input  varchar(200)
   inz( '[{"Rel": "detail","Href": "https://apisandbox.electioapp.com"}]' );
dcl-ds  results  dim(99) qualified;
   // rel   char(20);
   href  varchar(200);
data-into results %data( input: 'case=any allowextra=yes')
                  %parser('YAJL/YAJLINTO');
The reason that "rel" is not accepted as a field name is that it is the name of an opcode (RELease) - luckily you don't need it!
And ... you need allowextra=yes - not missing as there is data in the document (rel) with no home!
brianjgarland
Contact:
Post by brianjgarland »
If in the future you need rel, you can just define it using dcl-subf inside your DS.
Duh ... I knew there was a way of doing that but had forgotten. Thanks for the memory jog Brian.
If you want to include "rel", you can... you just have to put "dcl-subf" in there so it knows it's not the opcode.
   dcl-subf rel   char(20);
   href  varchar(200);
kdanforth
Post by kdanforth »
Thank you all. Exactly what I needed.
