Retrieval of log file information
IBMOLIVIER
Post by IBMOLIVIER »
Hello, in the Log file how to retrieve this message in my program ?
{"utilisateurID":["Unexpected character encountered while parsing value: }. Path 'utilisateurID', line 1, position 288.","Unexpected end when deserializing object. Path 'utilisateurID', line 1, position 5000."]}
comm_blockread returned 211
In my code I have this which actually retrieves the following information "400 "
Prm_Retour = %Char(Rc);
// Inserer le contenu du .json dans une table
data-into putapiwms_err %DATA(%Trim(FILENAME)
:'doc=FILE case=convert allowmissin
allowextra=yes trim=none countprefi
%PARSER('YAJLINTO');
Prm_MessageErreur = putapiwms_err.validationResult
Prm_LogLevel = putapiwms_err.validationResult
unlink(Filename);
http_error(Erreur_http);
wwErrorMsg = http_error(Erreur_http);
http_dmsg('SetError() #' +
%trim(%editc(Erreur_http:'L')) +
': '+ wwErrorMsg);
Prm_Retour = %subst(wwErrorMsg:10:3);
Log file:
HTTP/1.1 400 Bad Request
Server: openresty
Date: Tue, 28 Mar 2023 09:11:42 GMT
Content-Type: application/json; charset=utf-8
Transfer-Encoding: chunked
Connection: keep-alive
X-Gravitee-Transaction-Id: 7dabedff-3b46-4fa6-abed-ff3b464fa622
X-Gravitee-Request-Id: 7dabedff-3b46-4fa6-abed-ff3b464fa622
X-Powered-By: ASP.NET
recvresp(): end with 400
recvdoc parms: chunked 0
recvchunk(): entered
get_chunk_size(): entered
d3
chunk size = 211
get_chunk_size returned 211
calling comm_blockread
0
chunk size = 0
get_chunk_size returned 0
Re: Retrieval of log file information
You haven't shown us the code that calls HTTPAPI... but, basically, you will get this JSON document as output from HTTPAPI.
For example, if you're doing:
jsonDoc = http_string(url: other-parameters-here);
Then jsonDoc will be the JSON you are showing -- it doesn't matter that it's a 400 error -- it'll still be filled in.
