Passing in alternate field delimiters.
Scott Klement's tool for processing CSV files in an RPG program. http://www.scottklement.com/csv/
bozeyed_joe
Post by bozeyed_joe »
We were just wondering is there a parameter that be set to use a different field delimiter on your CSVINTO parser?
We have a number of files incoming that use Pipe rather than Comma.
Many thanks in advance.
Mick
Re: Passing in alternate field delimiters.
Currently, no... it always uses a comma.
You can edit the CSVINTO program and change it here:
      h = CSV_openBuf( parm.data: parm.dataLen: parm.dataCCSID
                     : *omit: *omit: *omit: *on );
Change it to:
                     : *omit: *omit: '|': *on );
Naturally you can add the ability to set that value at run-time if you want... you'll have to modify the code to make that work, it's something I've not had a need to do. If you feel that you've done a particularly nice job of it, please contribute it back to the project (post your changes here) so that others can take advantage of it.
bozeyed_joe
Okay thanks for the pointer.
I will take a look.
Cheers
Mick
