Hello, I have to consume a REST web services that responds to this link:
https://export-api-staging.lorch.cloud/ ... /weldseams? from_start_time_utc=1640993522&to_start_time_utc=1658323083".
I should consume it in GET so that it returns a JSON containing the requested information.
From what I can see from debugging, the request is done like this:
GET /api/export/weldseams?from_start_time_utc=1640993522&to_start_time_utc=1658323083 HTTP/1.1.
The REST web services tells me: HTTP/1.1 422 Unprocessable Entity.
How can I prevent "HTTP/1.1" from appearing at the bottom of my request?
Thank you
Consuming REST API - String "HTTP/1.1"
Re: Consuming REST API - String "HTTP/1.1"
Sorry, what are you coding to get the result you are seeing?
sandrocarosso
Good evening Scott,
thanks for your reply.
This is the command the API provider sent to me (he specified that I can also use "Application/json")
I try to post what I coded to get the result that I am attaching.
This is what I get from debugging:
This is the code I use
Thank you for the support you can provide me
Sandro
curl -X GET -H "X-Api-Key: 2KTV8VRAiUk-tvh7TyS_tf6t5qHSo3qAlWySDrHBC3o" -H "Accept: text/csv" "https://export-api-staging.lorch.cloud/api/export/weldseams? from_start_time_utc=1640993522&to_start_time_utc=1658323083"
OS/400 Ver V7R4M0
DNS resolver retry : 2
DNS default domain: CORAL.eu
DNS server found: 10.0.0.1
DNS server found: 10.0.0.2
https_init(): entered
QSSLPCL = *OPSYS
initializing GSK environment
GSK Environment now available
SNI hostname set to: export-api-staging.lorch.cloud
Cert Validation Code = 6000
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
Serial Number: 0D:66:E8:A4:A3:63:3A:79:09:94:64:BC:58:C3:1B:95
Common Name: export-api-staging.lorch.cloud
Issuer CN: GTS CA 1D4
Issuer Country: US
Issuer Org: Google Trust Services LLC
Version: 3
not before: 20230515020537
Unknown Field: 02:05:37 15-05-2023
not after: 20230813025749
Unknown Field: 02:57:49 13-08-2023
Unknown Field: 0382010F003082010A0282010100A8042C2D0AD41A611BFE19D719F3181F0ECAD525D2E748B6EA9F25E0DE229E9E446D5202A04F90D5179812F3861040E4784E0FFB8FB77279E9B0708151E161CF021665A31C548786FF0A0C5FA9BD65DB5D9F0558F4942D140C17E23ABD11270249B03B2DA6FBEA3DDA78C42761EF1155A02D577DE398333E75271E3ABEE1046C5A399757B74833648B4FC5027501490DF1F995F519099658DA9B0FF68CA94C2E6889B379ED17F2BB9B9A0E75D57CDD37DB232153E52F3DA4D63FF93D48D4C84A289CE5DC006F9663552FCAA0B39CDD01B845D1F9AB42E64437F428889865F89985BF2CC9450984C483813566875F53573765D8D149984073BADAEB1FD7526E850203010001
Unknown Field: 2048
Unknown Field: 0B294732F59C896A181A6823C8D9F49A
Unknown Field: 310C04285FD3EAC8D9EA39D7841DC145C221BACC
Unknown Field: 3ABCDA6516318C1DB06C9BA636566166F25AC088A1E96BD19034036713216B91
Unknown Field: 5
Unknown Field: export-api-staging.lorch.cloud
Unknown Field: 0
Unknown Field: 1.3.6.1.4.1.11129.2.5.3
Unknown Field: 2.23.140.1.2.1
Unknown Field: http://ocsp.pki.goog/s/gts1d4/oHtGNeU1x-c
Protocol Used: TLS Version 1.3
do_oper(GET): entered
Host: export-api-staging.lorch.cloud
User-Agent: http-api/1.45
X-API-KEY: oQdEmSAq8_Auo38bHmR2ulRifusIAKGpeAJgfsRiqcw
Date: Sat, 20 May 2023 17:50:15 GMT
Content-Length: 0
Via: 1.1 google
Alt-Svc: h3=":443"; ma=2592000,h3-29=":443"; ma=2592000
SetError() #13: HTTP/1.1 422 Unprocessable Entity
recvresp(): end with 422
recvdoc parms: identity 0
recvdoc(): Receiving 0 bytes.
// Generate the JSON document to send
http_debug(*on: '/lorch/log/wsmes0.txt');
$Apikey='oQdEmSAq8_Auo38bHmR2ulRifusIAKGpeAJgfsRiqcw';
: %paddr(addSpecialHeaders)
: %addr($Apikey) );
url = 'https://export-api-staging.lorch.cloud/api/'+
'export/weldseams?from_start_time_utc='+
%Trim(inizio)+
'&to_start_time_utc='+
%Trim(fine);
rc = http_req('GET': %trim(url): *omit: Response: *omit:
request: *omit);
httpcode = http_error();
dsply httpcode;
If 1=2;
DATA-INTO result %DATA(response:'case=convert allowextra=yes')
%PARSER('YAJLINTO');
Endif;
end-proc;
Dcl-Proc addSpecialHeaders;
Dcl-Pi *N;
headersToAdd Varchar(32767);
var like($Apikey) const;
End-Pi;
Dcl-c CRLF x'0d25';
headersToAdd = 'X-API-KEY: ' + var + CRLF;
End-Proc;
/end-free
Sandro
Did you actually try that curl request? Because when I try it I get the same basic error that you are seeing in your code.
Sandro,
422 Unprocessable Content means that the request entity (the headers and data you sent) was a valid syntax, but it was unable to process the request for some reason. (It does not explain further than that.)
Here are some things I noticed, though:
I don't see anything wrong with the "HTTP/1.1" as you said in an earlier post. This HTTP version is a part of the HTTP protocol, and is required -- removing it would make the request completely invalid.
- The curl example sets the 'Accept' header to text/csv. You are not doing that.
- The curl example sets the "X-Api-Key:" header, but you've provided "X-API-KEY:". I don't know if the upper/lower case matters to the server.. but it's possible? I don't see why you wouldn't make them match??
sandrocarosso
Thanks everyone for the suggestions!! I also entered "Accept: application/json" and now the webservice returns me the data I need, in addition to the corrections you suggested.
Thank you all
Thank you all
