400 Bad Request
moni_66
400 Bad Request
Post by moni_66 »
this is my first time using httpapi functions and I need some help.
I have to send a string to an external webservice and the external company provided me a command that work fine.
I tried to replicate it into rpgle program, but when I run the program I developed, I get 400 Bad Request error.
What am I doing wrong?
The original command is:
curl --location 'https://api-qty.company.com/gateway/ch-dw2000/v1/files/sample' --header 'X-COMPANY-TRANSACTIONID: EsempioCSVdaDW2000.csv' --header 'Content-Type: text/plain' --header 'Authorization: Bearer eyJraWQiOiI1OGE3NzBkMC03MWFlLTExZWQtOWUwYS1iZGMzMzY3MDA4NGQiLCJhbGciOiJSUzI1NiJ9.eyJjbGllbnRfaWQiOiI2Mzc1MjUyNi0yNGRmLTRiYjgtOWUwZC0wMmE4ZjU3YTFhYWMiLCJpc3MiOiJodHRwczovL2F1dGhndy1xdHkuYm9uZmlnbGlvbGkuY29tL2FzIiwiaWF0IjoxNjg1NjIyNzI2LCJleHAiOjE2ODU2MjYzMjYsImF1ZCI6WyJBUEkiXSwic2NvcGUiOiJhcGktaXQtZGlnaXRhbCJ9.SLa-JOCZUwDKN9xOTenymThoGXSOc5xvdl3cWOlYgZIdPLi54L-Hns-gPYU0Rk5lhnD675nl4Qj__j7zGkqvBbbC8aVQimu0l_0JDA-Bxl9ys2c2yvem-hngN5csdindlXe5xDSxMr7nozKLs8I-hVwvBn98KVnOEV6f_JxWjx--zYScmsIcmDd60DmpEli8So2Oaixvjc5atfuICWf9b3IeWxyiiaF8I3iX6jqwGFyo14RvFdDTe7g1LAeQh6Ul7Sai54V-1r3IxQ8Kr9uW_RYbJCW37xfKsPDCNl5GKSoSRntxuJQffltMeu7jRDx7AaA7KJbF9Aa-gpubE3wfKg' --data 'Field1|Field2|Field3 /n Riga1_F1|Riga1_F2|Riga1_F3 /n Riga2_F1|Riga2_F2|Riga2_F3 /n Riga3_F1|Riga3_F2|Riga3_F3 /n'
This is my program
     d rtcd            s              1a
     d psds          esds
     d url             s            256a   inz
     d poststring      s          32760a   inz
     d contenttype     s          16384a   varying inz('application/x-www-f-
     d                                     orm-urlencoded')
     d dsresult        ds
     d   errdes                     500    inz
     d   errnro                      10i 0 inz
     d   rspcod                      10i 0 inz(200)
     d rc1             s             10i 0
     D Add_Headers     PR
     D   Header                    1024A   varying
     D   UserData                      *   value
     d entry           pr                  extpgm('BONFIDAT')
     d   token                     1000a
     d entry           pi
     d   token                     1000a
      /free
        // The command to replicate is
        // curl --location 'https://api-qty.company.com/gateway/ch-dw2000/v1/files/sample'
        // --header 'X-COMPANY-TRANSACTIONID: EsempioCSVdaDW2000.csv'
        // --header 'Content-Type: text/plain'
        // --header 'Authorization: Bearer eyJraWQiOiI1OGE3NzBkMC03MWFlLTExZWQtOWUwYS.....ffltMeu7jRDx7AaA7KJbF9Aa-gpubE3wfKg
        // --data 'Field1|Field2|Field3 /n Riga1_F1|Riga1_F2|Riga1_F3 /n
        //    Riga2_F1|Riga2_F2|Riga2_F3 /n Riga3_F1|Riga3_F2|Riga3_F3 /n'
        callp http_debug(*ON:'/users/mob/bonfidat_debug.txt');
        // Url to send
        url = 'https://api-qty.company.com/gateway/'
          + 'ch-dw2000/v1/files/sample';
        // setting headers
        http_xproc(HTTP_POINT_ADDL_HEADER : %paddr(Add_Headers));
        http_setOption('content-type':'text/plain');
        // set authorization via token
        http_setAuth(HTTP_AUTH_NONE:'':'');
        http_setAuth(HTTP_AUTH_BEARER:'':%trim(token));
        // prepare data to send
        postString = 'Field1|Field2|Field3 /n Riga1_F1|Riga1_F2|Riga1_F3 /n'
           + ' Riga2_F1|Riga2_F2|Riga2_F3 /n Riga3_F1|Riga3_F2|Riga3_F3 /n';
          rc1 = http_post(%trim(url)
            : %Addr(postString) + 2
            : %Len(postString)
            : '/users/mob/inviobonfi.txt'
            : HTTP_TIMEOUT
            : HTTP_USERAGENT
            : 'text/plain' );
        on-error *all;
          errdes = http_error(errnro:rspcod);
        if rc1 <> 1;
          // handle error
        callp http_debug(*OFF);
        // fine sofferenze
        exsr exit;
        // subroutines
        begsr *pssr;
          dump PsDsPgmNam;
          *inlr = '1';
        endsr;
        begsr exit;
          *inlr = '1';
        endsr;
     P Add_Headers     B
     D Add_Headers     PI
     D   UserData                      *   value
      /free
        Header = 'X-COMPANY-TRANSACTIONID: '
          + 'EsempioCSVdaDW2000.csv'
          + x'0d25';
      /end-free
     P                 E
And this is the debug file
OS/400 Ver V7R4M0
http_setauth(): entered
http_url_post(): entered
DNS resolver retry  : 2
DNS default domain: mycompany
DNS server found: 10.0.xx.xxx
DNS server found: 10.0.xxx.xxx
DNS server found: 212.xxx.xxx.xxx
SNI hostname set to: api-qty.company.com
Cert Validation Code = 6000
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
Serial Number: 0B:D4:7D:8A:03:3C:64:07:17:5A:42:B8:2D:96:7D:E8
Common Name: api.company.com
Country: IT
Locality: xxx
Org Unit: Company S.p.A.
Issuer CN: GeoTrust RSA CA 2018
Issuer Country: US
Issuer Org: DigiCert Inc
Issuer Org Unit: www.digicert.com
Version: 3
not before: 20220901020000
Unknown Field: 02:00:00 01-09-2022
not after: 20231003015959
Unknown Field: 01:59:59 03-10-2023
Unknown Field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
Unknown Field: 4096
Unknown Field: C4462CCB6C9327EBEB9816A7E0456706
Unknown Field: 1EA4315CFB7863E692CFE31F61763839C826949D
Unknown Field: E6DCB12F56C9F000776303467C12F5AC7F3232AD75925966DEC76C1EABBC7C30
Unknown Field: 5
Unknown Field: api.company.com
Unknown Field: 0
Unknown Field: 2.23.140.1.2.2
Unknown Field: http://status.geotrust.com
There are 1 cookies in the cache
cookie=ssnid not sent (expired)
POST /gateway/ch-dw2000/v1/files/sample HTTP/1.1
Host: api-qty.company.com
User-Agent: http-api/1.45
Content-Length: 32760
HTTP/1.1 400 Bad Request
Date: Thu, 01 Jun 2023 14:11:38 GMT
Content-Type: text/html
Content-Length: 150
Connection: close
Server: APIGW
SetError() £13: HTTP/1.1 400 Bad Request
recvresp(): end with 400
recvdoc parms: identity 150
SetError() £0:
recvdoc(): Receiving 150 bytes.
<html>
<head><title>400 Bad Request</title></head>
<body>
<center><h1>400 Bad Request</h1></center>
<hr><center>nginx</center>
</body>
</html>
Thank you for the support you can provide me
Monica
Re: 400 Bad Request
I'm not sure what the purpose of the /n is in your data. Often people use \n (with a backslash) as shorthand for a newline character. Though, yours has a foreslash (/n) which is not quite the same -- but I'm still thinking perhaps it was meant for you to use a newline character in your data rather than literally providing the "/n" characters?
in RPG, you would typically do that like this:
postString = 'Field1|Field2|Field3' + x'25'
           + 'Riga1_F1|Riga1_F2|Riga1_F3' + x'25'
           + 'Riga2_F1|Riga2_F2|Riga2_F3' + x'25'
           + 'Riga3_F1|Riga3_F2|Riga3_F3' + x'25';
(possibly also with a space before the x'25'? But that is unusual.)
Also please consider using http_req instead of the old http_post -- http_post is "old school".
moni_66
Re: 400 Bad Request
Post by moni_66 »
Thank you Scott, today is vacation in Italy, on monday I'll try your suggest.
moni_66
Re: 400 Bad Request
Post by moni_66 »
I changed my program as you suggested
and
rc1 = http_req( 'POST'
             : %trim(url)
             : '/users/mob/inviobonfi.txt'// File to receive
             : *omit                      // String to receive
             : *omit                      // File to send
             : postString                 // String to send
             : contenttype);              // Content type       (text/plain)
but the result doesn't change.
This is the debug file
OS/400 Ver V7R4M0
DNS server found: 10.0.250.131
DNS server found: 10.0.254.251
DNS server found: 212.216.112.112
Country: IT
Locality: xxx
Org Unit:Company S.p.A.
Issuer Country: US
Version: 3
Unknown Field: 4096
Unknown Field: 5
Unknown Field: api.bonfiglioli.com
Unknown Field: 0
Content-Length: 102
Authorization: Bearer eyJraWQiOiI1OGE3NzBkMC03MWFlLTExZWQtOWUwYS1iZGMzMzY3MDA4NGQiLCJhbGciOiJSUzI1NiJ9.eyJjbGl.....
Date: Mon, 05 Jun 2023 07:47:01 GMT
Content-Length: 150
Connection: close
Server: APIGW
SetError() £0:
<html>
<body>
</body>
</html>
It is usual to obtain SetError() £13 with simbol £ ?
May be there is some problem about ccsid?
Thank you in advance
Monica
emaxt6
Re: 400 Bad Request
Post by emaxt6 »
I guess you are on an "italian" machine... you should see # actually
# in "american" has the same hex value as £ in "italian" (CCSID 37 and CCSID 280 usually involved).
So yes, maybe it is the stream file you are logging (or the viewer) to without correct ccsid.
try to leave the default (a file in /tmp is created).
Anyway the final behaviour doesn't change.
Regarding your service: if you have access to the people running the service ask for exact encoding detail and what they see.
Otherwise, if you have a successful curl, try to run curl with all the trace and verbose options on, to see what it is really exchanged via curl.
moni_66
Re: 400 Bad Request
Post by moni_66 »
now the program run fine, I removed http_setOption('content-type':'text/plain'); and declared it only http_req.
In other similar program, I simply replaced http_post with http_req and now it run fine.
Thanky you very much for your precious support.
Monica
