HTTP Auth Bearer
JasonWallace
HTTP Auth Bearer
Post by JasonWallace »
Ran into an issue with http_setAuth (HTTP_AUTH_BEARER ...
The Bearer token I got on an earlier call is 1065 in length.
But the prototype for the http_setauth only allows the pePasswd to be 1024 in lenght.
So the token is being cut off.
Suggestions?
Re: HTTP Auth Bearer
Are you able to use something like this?
ctl-opt dftactgrp(*no) bnddir('HTTPAPI');
/copy httpapi_h
dcl-ds TokenData qualified;
  Type  varchar(20);
  Value varchar(5000);
dcl-s result varchar(10000);
          : %paddr(Add_Token_Routine)
          : %addr(TokenData) );
TokenData.Type  = 'Bearer';
TokenData.Value = 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx+
                   xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx';
http_debug(*on: '/tmp/token_debug_log.txt');
result = http_string( 'GET': 'http://www.scottklement.com' );
dcl-proc Add_Token_Routine;
  dcl-pi *n;
     NewHeaders varchar(32767);
     Token      likeds(TokenData);
  dcl-c CRLF const(x'0d25');
  NewHeaders = 'Authorization: '
             + Token.type + ' ' + Token.value + CRLF;
end-proc;
JasonWallace
Apologies for never replying to this old post.
Yes I was able to get it work using http_xproc
