Hi All,
During auto-scaling, the Rest API application is down for 80 seconds. Our RPG code that is consuming this Rest API is ending in error during auto-scaling. I would like to setup timeout seconds (HTTP_TIMEOUT) as 120 seconds while posting request using http_url_post_stmf. I think the default is 60 seconds. Could you please tell me how to do it.
http_url_post_stmf(%trim(url)
: json_input
: json_response
: HTTP_TIMEOUT
: HTTP_USERAGENT
: content_type );
httpapi version installed - 1.45
Thanks in advance.
How to set Timeout seconds in http_url_post_stmf
stefan@tageson.se
- Contact:
Re: How to set Timeout seconds in http_url_post_stmf
What's stopping you from using 120 as the fourth parameter in the call to http_url_post_stmf?
Should we use any API to set timeout or directly give 120 seconds in the API call?
stefan@tageson.se
- Contact:
Have a look in qrpglesrc member httpapi_h and read up on the functions you are using:
* http_url_post_stmf(): Post data to CGI script from stream file
* peURL = url to post to (http://www.blah.com/cgi-bin/etc)
* pePostFile = Filename (in IFS) of file to send to http server
* (request body document)
* peRecvFile = Filename (in IFS) of stream file containing reply
* (response body document)
* peTimeout = (optional) give up if no data is received for
* this many seconds.
* peUserAgent = (optional) User-Agent string passed to the
* server. Pass *OMIT for the default
* peContentType = (optional) content type (MIME type) to supply
* to the server. Pass *OMIT for default.
* peSOAPAction = (optional) string used to specify the action
* taken by some SOAP applications.
* - pass *blanks to send an empty SoapAction.
* - pass *omit (or don't pass the parm at all) if
* you don't want a SoapAction header to be sent.
* Returns (same as http_url_post)
The fourth parameter gives you the option to set the timeout value in the call directly.
HTTP_TIMEOUT is just a constant containing the default timeout value from config_h. IF you want a different value, pass that value instead of HTTP_TIMEOUT
