Adding Auth Key to HTTP Header
mbwswim
Post by mbwswim »
I read a few posts on this and it was nto clear enough to me.
Some said to use HTTP _ADDL_HEADER or something like that and that is not active in HTTPAPI.
So I do not know what to use to send my auth key.
I can do this in postman, so I know it works, I just can't here and we want to get the data on to ibmi.
Re: Adding Auth Key to HTTP Header
Can you explain a little more? There are lots of different types of authentication. What are you trying to do?
Perhaps if you showed us what you are sending with Postman we could understand the type of authentication you are trying to do.
JJDalglish
Post by JJDalglish »
I know the below example is in curl, but since I don't how how to do it using HTTP, that is all I can provide right now.
Using HTTP, I'd like to know how to pass these values:
X-API-Key:
Return-Request:
Return-Response:
curl --location --request POST 'https://try-test.anysportsapi.com/department/create' \
--header 'X-API-Key: akdalsda9das8d980da0dasda' \
--header 'Return-Request: 0' \
--header 'Return-Response: 1' \
--header 'Content-Type: application/json' \
--data-raw '{"id": "9998","name": "Test Department 9998"}'
Thanks!
Take a look at this post - it shows how to add such headers.
viewtopic.php?p=97#p97
JJDalglish
THANK YOU !!!!!!!!!!
