I'm trying the API to do ftp. For the libraries part I have no problem, for the IFS part, for every attempt I make the message is returned to me "This path or directory does not exist" even if with the WRKLNK the file and the path exist.
I'm using a lpar with V7R5M0
No such path or directory on IFS
Re: No such path or directory on IFS
How can I reproduce this problem?
here there is a small code that run over your api.
I use 2 dsply in order to check that there aren't any white spaces. Using a DB2 path (/qsys.lib/...) I don't have any problem. With IFS, it returns me "This path or directory does not exist", probably cpe3025.
**FREE
Ctl-Opt decedit('0,') datedit(*dmy.);
ctl-opt main(setlogadm);
/COPY LIBFTP/QRPGLESRC,APIFTP
/INCLUDE DEVSRC/UTIAPI,APISYS
dcl-proc setlogadm;
dcl-s sess int(10) inz(0);
dcl-s to varchar(50) inz(*blank);
dcl-s msg varchar(50) inz(*blank);
dcl-s cmd varchar(50) inz('DLYJOB DLY(1)');
dcl-s from varchar(50) inz(*blank);
sess = FTP_conn('ftpserver': 'adm':'password');
Msg = ftp_errorMsg(sess);
dsply msg;
if sess<0;
dsply 'Connection error';
ENDIF;
from='/HOME/adm/ftpapi.savf';
to='/HOME/adm/ftpapi.savf';
dsply (':'+from+':');
dsply (':'+to+':');
FTP_binaryMode(sess: *on);
FTP_quote(sess: 'rcmd '+CMD);
FTP_NamFmt(sess: 1);
FTP_chdir(sess:'/HOME/adm/');
if FTP_put(sess:to:from)<0;
dsply 'FTP error';
dsply msg;
dsply 'OK';
ENDIF;
ftp_quit(sess);
end-proc;-
Thanks!
You've found a bug. FTPAPI tries to rename files that end in .SAVF to .FILE -- it does this because if you transfer a .SAVF from a library, the actual file type is .FILE -- so it adjusts the path accordingly.
However, it should only do that when the file is in a LIBRARY, not when it's in the IFS... which is the bug, it's doing it for IFS files as well, and shouldn't be.
I fixed it, and uploaded a new copy to the website. (First change to FTPAPI in 2 years!) Please see if that works for you. http://www.scottklement.com/ftpapi/
