How to add custom http headers
jasanchez
Post by jasanchez »
It may have already been asked, but I just can't find it.
How do I add custom http headers, like x-date?
Thanks.
Javier Sanchez
Re: How to add custom http headers
You use the http_xproc API with the first parameter of HTTP_POINT_ADDL_HEADER to specify your custom routine to be called and then build the required header content in that procedure.
Here's how I use it with Zoom APIs - this call has to occur before you invoke the http_string or whatever of the http APIs you are using to invoke the web service.
   // Notify httpapi of the routine to use to add headers
             : %paddr(addSpecialHeaders)
             : %addr(authorizationToken) );
The actual addSpecialHeaders() routine looks like this:
// AddSpecialHeaders
//   Called by httpapi to add the headers
//   In this case the header is just the authentication token (the JWT)
Dcl-Proc addSpecialHeaders;
   Dcl-Pi *N;
      headersToAdd    Varchar(32767);
      var             like(authorizationToken) const;
   End-Pi;
   Dcl-c  CRLF  x'0d25';
   headersToAdd = 'authorization: ' + var + CRLF;
End-Proc;
jasanchez
Post by jasanchez »
Excelent!
Thank you!!!!!
