ssl_error(415): (GSKit) Peer not recognized or badly formatted message received.
kdanforth
Post by kdanforth »
I'm getting an error on an API call when I use http_req(), but when I send the same payload using Postman, it works fine.
This seems to be an intermittent problem when calling the API from my IBM i. But it succeeds 100% of the time when called from Postman. Any help understanding the error would be greatly appreciated.
Debug Data:
HTTPAPI Ver 1.42 released 2020-10-12
OS/400 Ver V7R4M0
2023-10-13-13.43.56.112415: http_persist_open(): entered
2023-10-13-13.43.56.133356: http_long_ParseURL(): entered
2023-10-13-13.43.56.133492: DNS resolver retrans: 2
2023-10-13-13.43.56.133519: DNS resolver retry : 2
2023-10-13-13.43.56.133545: DNS resolver options: x'00000136'
2023-10-13-13.43.56.133586: DNS default domain: AMSCAN.CORP
2023-10-13-13.43.56.133615: DNS server found: 10.122.201.145
2023-10-13-13.43.56.133639: DNS server found: 10.13.106.77
2023-10-13-13.43.56.133665: DNS server found: 10.122.201.146
2023-10-13-13.43.56.181728: Nagle's algorithm (TCP_NODELAY) disabled.
2023-10-13-13.43.56.403779: SNI hostname set to: api.omniparcel.com
2023-10-13-13.43.56.697841: (GSKit) Peer not recognized or badly formatted message received.
2023-10-13-13.43.56.697974: ssl_error(415): (GSKit) Peer not recognized or badly formatted message received.
2023-10-13-13.43.56.698013: SetError() #30: SSL Handshake: (GSKit) Peer not recognized or badly formatted message received.
2023-10-13-13.43.56.698057: http_close(): entered
RPG Code:
// Activate debug logging (normally commented out)
http_debug(*On :'/s2k/temp/debug_wntms0b1.txt');
http_setDebugLevel(2);
// Set the CCSID to UTF-8 for API data
http_setCCSIDs(1208: 0);
// Create the consignment
Monitor;
http_xproc(HTTP_POINT_ADDL_HEADER
:%paddr(addSpecialHeaders)
rc = http_req('POST'
:%trim(url)
:*omit
:response
:*omit
:request
:'application/json'
JSON Payload:
"DeliveryReference": "1675199",
"Reference2": "1990133-000",
"Reference3": "MK0200768994",
"issignaturerequired": false,
"DutiesAndTaxesByReceiver": false,
"PrintToPrinter": false,
"IncludeLineDetails": true,
"Service": "eCommerce Standard Tracked",
"Outputs": [
"LABEL_ZPL_100X150"
"Origin": {
"Name": "Ginger Ray",
"ContactPerson": "Operations Supervisor",
"PhoneNumber": "0000000000",
"Email": "customerservice@amscan-uk.co.uk",
"Address": {
"BuildingName": "c/o Amscan International",
"StreetAddress": "Brudenell Drive",
"Suburb": "Brinklow",
"City": "Milton Keynes",
"PostCode": "MK10 0DA",
"CountryCode": "GB"
"Destination": {
"Name": "Bob Somebody",
"ContactPerson": "Bob Somebody",
"PhoneNumber": "(914) 111-2222",
"Email": "bobsomebody@gmail.com",
"SendTrackingEmail": true,
"Address": {
"BuildingName": null,
"StreetAddress": "1234 Rainbow Cove",
"Suburb": "Elmsford",
"City": "Elmsford",
"PostCode": "10523",
"CountryCode": "US"
"Packages": [
"Name": "0001 : KE8 LARGE GINGER RAY BAG",
"Length": 30.0000,
"Width": 30.0000,
"Height": 10.0000,
"Kg": 0.3600,
"Type": "Bag",
"OverLabelBarcode": "MK0200768994"
"Commodities": [
"Description": "Magician Burgundy Cape",
"HarmonizedCode": "6114300000",
"Units": 1,
"UnitValue": 34.5000,
"UnitKg": 0.2600,
"Currency": "GBP",
"Country": "CN",
"ItemSKU": "FD-125",
"IsDG": false
Re: ssl_error(415): (GSKit) Peer not recognized or badly formatted message received.
It basically means it doesn't understand the form of SSL (TLS) encryption that the remote server is sending.
Possibly you need to update HTTPAPI, or your operating system. Or perhaps the SSL/TLS support in the OS is misconfigured.
Abhinav Goel
Post by Abhinav Goel »
I am also facing Same issue. Could you please let me know what version of HTTPAPI should i upgrade to to fix this issue?
By Updating the HTTPAPI did the issue resolved for you or some other troubleshooting also needs to be done?
What version of TLS is being required?
What version of TLS is available in your copy of the operating system?
What ciphers are requested?
What ciphers are in your version of the operating system?
I can't help you if you provide no information.
