Alternate record delimiter
Scott Klement's tool for processing CSV files in an RPG program. http://www.scottklement.com/csv/
bsnuggs
Post by bsnuggs »
I'm trying to read a CSV that has some large fields in it that have LF's. The programs treats the LFs as record delimiters. Can I pass a parameter to a function that forces it to use CR+LF as the record delimiter?
Re: Alternate record delimiter
Right, it treats the LF as the delimiter. If there's a CR found, it just pretends it's not there.
You'd have to modify the code to work differently... since it's open source, you're able to do that.
