Good morning, I read data from a SQL server.
My as400 is V6R1
In Scott's manual, it says to:
Set CLASSPATH as follows:
ADDENVVAR ENVVAR(CLASSPATH) VALUE('/java/jdbc/jdts-1.3.1.jar')
In my as400 in the indicated directory:
/java/jdbc/
jdts-1.3.1.jar file is missing
How does it all work?
If I use the WRKENVVAR command I don't see anything, there is no CLASSPATH.
Can anyone help me understand? Thank you
Accesssing External Databases
Re: Accesssing External Databases
V6R1 won't run on an AS/400. The last AS/400 was made 24 years ago. It is time to get a new computer.
Did you download the jar file into that directory?maxino wrote: Sun Jan 21, 2024 9:24 am In Scott's manual, it says to:
/java/jdbc/
You download the JDBC driver that you want to use and put it somewhere in the IFS on your system, then point the CLASSPATH variable to it so that it knows where to find it.
Did you run the ADDENVVAR command that you mentioned, above? That will ADD the ENVironment VARiable so that WRKENVVAR will see it. It won't be there if you (or someone) doesn't add it.maxino wrote: Sun Jan 21, 2024 9:24 am If I use the WRKENVVAR command I don't see anything, there is no CLASSPATH.
Also there are two different levels it can be added at. The *SYS (system) and *JOB level. IF you add it at the job level, it will only exist for the duration of your job. If you add it at the system level, it will be copied to a job-level variable the first time anyone uses an environment variable in the job. So if you added it at the system level, it may not show up until you sign off and on again. (But unlike *JOB, the *SYS level will exist for all jobs, and persist when your job ends.)
Thanks for the reply Scott.
If programs work ONLY if a CLASSPATH exists, I certainly did the ADDENVVAR command.
The question is, how do I see where I put the jar file?
If it's not in /java/jdbc/ where is it?
Is there a command to see where I put it?
Best regard
PS:
The ADDENVVAR command was almost certainly done at system level, because every time I run an RPG program to read an external database in the CLP I don't indicate the ADDENVVAR.
Best regard
PS:
Normally, Java will only find JAR files that are explicitly listed in the CLASSPATH. So if you are telling me that it's not located where it's listed in the CLASSPATH, then I'm very confused.
The only thing I can think of is that someone put it into the Java Extensions directory. Last time I used it, it was /QIBM/UserData/Java400/ext -- look and see if the JAR is in there. But... if it's there, then why do you need to set a CLASSPATH at all? Note: I do NOT recommend putting JAR files in this folder because that means that Java is to treat them as "extensions" that are always loaded and available. That means you can't use different versions of the same JAR file, and it means that every project loads it whether it needs it or not. It's much better to use CLASSPATH.
As for a tool to find where you put it.... Surely when you uploaded it you picked a location? Do you not remember? I suppose you could search all of the IFS for it -- but obviously that could take a long time.
Thanks Scott for the reply.
I found the sqljdbc.jar file
It's in the directory
Perhaps I referred to an old article of yours in which you indicated this directory.
Thanks again
Thanks again
