Hello everyone.
IBM has made backward incompatible changes in the framework https://www.ibm.com/support/pages/node/6848167 . Question: is there any way to change this default behavior of the AXIS framework at the system-wide level?
HTTP client transport supports binary payloads (backward compatibility)
Re: HTTP client transport supports binary payloads (backward compatibility)
Can you explain what you mean by "change this default behavior... at the system-wide level"? It seems to me that it's already changed at the system-wide level. Can you explain what problems it causes you? I'm not seeing why it would cause problems.
Also, why are you asking this in the HTTPAPI forum? This has nothing whatsoever to do with HTTPAPI -- your question is about AXIS.
