handling body
RINALDI_V
handling body
Post by RINALDI_V »
Good evening, I would like to ask a question about managing the body in a POST request for a token.
I am using the function http_string('POST': url: SendStr: 'application/json');
URL :http://<localhost>/tse_webapi/auth/token
SendStr: SendStr = '{"grant_type":"password","username":"<xxx>"'
+ ',"password":".<xxx>"}';
Thank you in advance :)
Re: handling body
Sure thing. What is the question?
RINALDI_V
Re: handling body
Post by RINALDI_V »
Sorry, how can I include the Body information (as shown in the attached screenshot) in my request? The reference request is
URL = 'http://192.168.16.119:81/tse_webapi/auth/token';
SendStr = '{"grant_type":"password","username":"admin"'
+ ',"password":".Admin01"}';
response = http_string('POST': url: SendStr: 'application/json');
msg = http_error();
Screenshot 2024-06-27 185249.png (77.62 KiB) Viewed 23023 times
Re: handling body
You are including it in your request.
Did you mean to encode it as URL-encoded form data instead of as a JSON document, like the Postman screenshot?
Re: handling body
I think you want something like this:
dcl-s userid varchar(128) inz('admin');
dcl-s password varchar(128) inz('.Admin01');
dcl-s url varchar(1000);
url = 'https://192.168.16.119/tse_webapi/auth/token';
SendStr = 'grant_type=password'
        + '&username=' + http_urlEncode(userid)
        + '&password=' + http_urlEncode(password);
                        : url
                        : SendStr
  msg = http_error();
RINALDI_V
Re: handling body
Post by RINALDI_V »
Thank you very much, this way it works!
