comm_blockread failed! / large jsonfile
AS400Guy
Post by AS400Guy »
I've a problem with a large jsonfile.
It is chunked in different blocks, but it looks like the last block crashes.
I got an error: 'comm_blockread failed!'.
See below the relevant part of the log:
chunk size = 8192
get_chunk_size returned 8192
calling comm_blockread
{"Orders":[...,"uomDescription":"Piece",
comm_blockread returned 8192
get_chunk_size(): entered
2000
chunk size = 8192
"status":"S03",...,"statusText":"Shipped"}]}
2000
chunk size = 8192
},{"orderId":"58446",...,{"material":"000
2000
chunk size = 8192
170",...,{"material":"000069","description":"Aphid
Does anyony has an idea how to solve this?
Kind regards,
AS400Guy
Re: comm_blockread failed! / large jsonfile
The server is saying that it is sending 8192 bytes (hex 2000) of data to you. It is disconnecting after sending only 50 bytes. This doesn't appear to be a problem in HTTPAPI. Either the network is getting disconnected, or the server program is ending before all of the data is properly sent.
AS400Guy
Post by AS400Guy »
A very strange situation.
Today it's working. I didn't change anything at my side...
Not really strange at all.
