1) Suppose if my field name and record format name is too long then how can i fit it into Functions under DDS for below case( I am referring this link :-When to specify REF and REFFLD keywords for DDS files - IBM Documentation)
5: FIELD6 has the same attributes as FLD6 in record format RECORDB in FILE4 in LIB1.
currently what happening is that just for example for my case number 5:-
FIELD6 R REFFLD(RECORDB/FLD6 LIB1/FILE4) (5) --> here due to combination of all this it's not fitting in single line and going to next line so i can i complete remaing file name in next line here ?
Any example to overcome this issue here please?
2) Suppose if i have to create a new file with below conditions for it's fields:-
field1 from file1 should be concatenated with field2 of this same file1 where FIELD2 NE BLANK ,else concatenate to FIELD3+FIELD4 of this same file1.
Any example to fulfil this condition for this case please?
Thanks.
creating a file using DDS
Re: creating a file using DDS
You can use + to continue data on the next line
A FIELD6 R REFFLD(RECORDB/FLD6 +
A LIB1/FILE4)
thanks much and what about second case here please?
Thanks much...
Thanks much...
I've never done anything like that in DDS, so I don't know the answer to #2.
Is there a reason you're using DDS for this instead of SQL?
Or for that matter, just do it in a program?
Ok, If i try SQL table for the same my tjis SQL query does not work:-
"CREATE TABLE NewTable AS
SELECT
Field1 AS NewField1,
Field2 AS NewField2,
Field3 AS NewField3,
CASE
WHEN Field2 <> '' THEN Field1 || Field2
ELSE Field3 || Field4
END AS ConcatenatedField
FROM File1"
any corrected version of the same please?
thanks..
SELECT
CASE
FROM File1"
thanks..
Apart from that concatenation of the fields i want some fields to be referred from fiel1 some from fiel2 and some from file 3 likewise and these files could be sometime in same library and may be in different library plus i want to add some custom fields with my choice of data type and length in this table's structure.
but currently unable to form a table :
tried below SQL query but it's not getting executed getting this error:-"Keyword FROM not expected. Valid tokens: FOR USE SKIP WAIT WITH FETC "
CREATE TABLE l1/t1 AS (
SELECT
f1.field1 AS NAME1,
f1.field2 AS NAME2,
f1.field3 AS NAME3 ,
f2.field4 AS NAME4 ,
f4.field5 AS NAME5 ,
f1.field6 AS NAME6 ,
f1.field7 AS NAME7 ,
f1.field8 AS NAME8 ,
f1.field9 AS NAME9
FROM LIB1.FILE1 as f1
FROM LIB1.FILE2 as f2
FROM LIB2.FILE3 as f3
) WITH NO DATA
Awaiting experts advice here for the same to be able to create desire table(file) structure here.
Thanks.
SELECT
f1.field1 AS NAME1,
f1.field2 AS NAME2,
f1.field9 AS NAME9
) WITH NO DATA
Thanks.
Are your questions in this thread related?
You were asking previously about concatenating fields... You would never be able to do that in a create table statement.
