http_req
almond
http_req
Post by almond »
Dear
When using http_req, the "File to receive" function works fine, but how can I use the "String to receive" option to receive a JSON body like this?
"encryptString": "138",
"hexString": "5BF28981860"
my code
D rc              s             10I 0
D msg             s             25A
D url1            s            300A
D url2            s            300A
D parm1           s            100A
D parm2           s              8A
D responseBody    s               a   len(16000000) varying
D debugLog        s             32A   varying inz
D urlFull         s          32767a   varying
D res             s             50a
 /free
    url1 = 'http://192.168.0.1:9090/test/api';
    parm1 = 'encryptString=138';
    urlFull = %trim(url1) + %trim(parm1);
    debugLog = '/home/qsnp252/' ;
    http_debug(*ON: debugLog + 'testrest.log');
    http_setOption( 'content-type'
              : 'application/json' );
rc = http_req( 'GET'
              : urlFull
              : '/home/qsnp252/test.json'    // File to receive
              : responseBody                 // String to receive
              : *omit                        // File to send
              : *omit                        // String to send
if rc <> 1;
     msg = http_error();
     dsply ('error:' + msg);
   res = %subst(responseBody : 1 : 50);
   dsply res;
   dsply 'OK';
   https_cleanup();
/end-free
stefan@tageson.se
Contact:
Re: http_req
Post by stefan@tageson.se »
Unless I'm misunderstanding something - just code *OMIT for the file to receieve parameter.
You can't use both file to receive and string to receive in the same call.
almond
Re: http_req
Post by almond »
Thanks for your reply!
it can works using both parameters ,but i don't know hot to parse the responseBody like json body .
almond
Re: http_req
Post by almond »
i'm sorry, i set parameter of ResultStmf is *OMIT
i code like this could work,the response could display the json result
thank you very much!
%size(%trim(responseBody ))
Re: http_req
almond wrote: Fri Jul 26, 2024 11:15 am i code like this could work,the response could display the json result
I don't understand this at all.
Note that %SIZE is very different from %LEN. %SIZE tells you how many bytes of memory the variable is using, whereas %LEN tells you the current length of the data in the string. So %SIZE(%TRIM()) doesn't make any sense... trimming blanks from the data has no impact on how much memory the variable occupies.
Furthermore, I don't understand where you would use this. You can't pass the size to http_req, so what are you using it for?
The length of the data (returned via %LEN) is set by http_req, so unless the server is adding extra leading or trailing blanks, there's no reason to use %TRIM. This whole discussion makes no sense.
almond
Re: http_req
Post by almond »
i just want to dsply the responsbody to verify the results
dsply %size(%trim(responseBody));     // display the json body size
dsply %subst(%trim(res: 1 :50);
Re: http_req
Then you should be doing %len(responseBody) not %size(%trim(responsebody))
almond wrote: Mon Jul 29, 2024 1:29 am i just want to dsply the responsbody to verify the results
almond
Re: http_req
Post by almond »
thx very much
then I'll try the YAJL to analysis the respondy
