mystery cookie being sent in the header
dustinm
Post by dustinm »
I am attempting to retrieve an Oauth 2.0 token. About half the time it works fine. Then, seemingly randomly, I start getting Error 400 bad request returned. This is my request
http_setCCSIDs(1208: 0);
http_debug(*ON);
http_xproc( HTTP_POINT_ADDL_HEADER : *NULL);
authparms = 'grant_type=client_credentials&client_id='+
   %trim(facid)+'&client_secret='+%trim(facsec);
if http_req('POST'
                    : %trim(faurl1)+'/oauth2/v3/token'
                    : *omit
                    : RSP
                    : *omit
                    : %trim(authparms)
                    : 'application/x-www-form-urlencoded') <> 1
     errmsg = http_error(errno:result);
The response I am getting is:
{"fault":{"faultstring":"OASValidation OpenAPI-Spec-Validation-OAuth2 with resource \"oas:\/\/oauth2-3_0_2.yaml\": failed with reason: \"[ERROR - cookie parameter is unexpected : NSC_fnbt-bqj-dbu: [], ERROR - cookie parameter is unexpected: $Path: [], ERROR - cookie parameter is unexpected : $Version: []]\"","detail":{"errorcode":"steps.oasvalidation.Failed"}}}
This lead me to look at httpapi_debug.txt and there is a cookie header being sent that I am never specifying. It is only there when the request fails.
There are 1 cookies in the cache
POST /oauth2/v3/token HTTP/1.1
Host: api-cat.usps.com
User-Agent: http-api/1.45
Content-Type: application/x-www-form-urlencoded
Content-Length: 103
Cookie: $Version=0; NSC_fnbt-bqj-dbu=ffffffff3b449a5145525d5f4f58455e445a4a42378b; $Path=/;
Where is this coming from and how do I get rid of it?
Re: mystery cookie being sent in the header
dustinm wrote: Wed Aug 21, 2024 11:57 pm Where is this coming from and how do I get rid of it?
When a prior request to the same host sent a cookie, HTTPAPI will automatically send it back on the next request (unless the cookie has expired.) This is a normal part of the HTTP standard. By default, HTTPAPI only 'remembers' and resends cookies until the activation group ends.
If you want to disable cookies completely, code this near the beginning of your program (anywhere before you make HTTP requests):
http_use_cookies(*OFF);
dustinm
Post by dustinm »
Is the cookie being sent to me from the server and then HTTPAPI is sending it back? I'm just not sure where it originated from, I'm not using cookies at all. That would make sense if it's originating from the server I'm calling.
At any rate, http_use_cookies(*OFF) seems to have fixed my issue and it works since I don't want to use them anyway. Thank you!
dustinm wrote: Thu Aug 22, 2024 8:26 pm Is the cookie being sent to me from the server and then HTTPAPI is sending it back?
Yes.
