MCH1210 in do_iconv_real procedure FTPAPI
Discussions related to FTPAPI (An FTP client package for RPG programming.) http://www.scottklement.com/ftpapi/
Cinzia
Post by Cinzia »
Good morning,
I recently downloaded ftpapi 2.8 and started using it.
I debugged it and got this error:
MCH1210 in the function
dcl-proc do_iconv_real export; present in the FTPTCP member of the QRPGLESRC file.
In particular, I found the error when running:
rc = iconv( ictbl
: p_inputBuf
: inputLeft
: p_outputBuf
: outputLeft );
I can't understand why I get the error, can you help me?
Cinzia
Re: MCH1210 in do_iconv_real procedure FTPAPI
Post by Cinzia »
I solved MCH by changing the definition of RC from int(10) to uns(10)
However I have a problem during ftps, the commands are taken correctly, but as soon as "TYPE I" is written the system does not recognize the command.
Checking in debug I see that the RC of the iconv in the do_real_iconv procedure is 4294967295, could this be the problem? Why does it happen?
0: > USER DCM_ADMIN
0: 331 Enter password.
0: > PASS **********
0: 230 DCM_ADMIN logged on.
0: > PBSZ 0
0: 200 PBSZ accepted.
0: > PROT P
0: 200 PROT accepted.
0: > RCMD CRTSAVF DSCOBJDCMW/WO00050475
0: 250 Command CRTSAVF DSCOBJDCMW/WO00050475 successful.
0: > TYPE I
0: 500 Subcommand  not valid.
0: > QUIT
Cinzia wrote: Mon Dec 09, 2024 9:23 am Checking in debug I see that the RC of the iconv in the do_real_iconv procedure is 4294967295, could this be the problem? Why does it happen?
iconv() was designed strangely. It returns uns(10) normally, but for errors return -1. uns(10) means "unsigned", whiuch means it cannot have a negative value. So it is a strange design.
In the C prgoramming language a signed value of -1 is the same as an unsigned value of 4294967295. so if the variable contains 4294967295, you could check it against -1 in C and it would work. In RPG you have to check it against 4294967295, however.
I can fix that, but a bigger question is, why is iconv() failing to begin with?
Is is trying to convert the string "TYPE I" from EBCDIC to ASCII to send it to the FTP server. When converting, iconv() is returning ICONV_FAIL, so it is return an empty string '', that's why you see the message "Subcommand <blank> not valid" because TYPE I is now translating to blank.
I can't imagine how that would happen, as TYPE I is entirely made of invariant characters.
Please tell me how I can reproduce this on my own system.
Cinzia
Post by Cinzia »
this is the debug value:
EVAL ictbl
ICTBL.RETURN_VALUE = 0
ICTBL.CD(1) = 280
ICTBL.CD(2) = 1208
ICTBL.CD(3) = 0
ICTBL.CD(4) = 0
ICTBL.CD(5) = 0
ICTBL.CD(6) = 0
ICTBL.CD(7) = 0
ICTBL.CD(8) = 33056
ICTBL.CD(9) = -1396812187
ICTBL.CD(10) = -455061503
ICTBL.CD(11) = 0
ICTBL.CD(12) = 0
INP =
     1   'TYPE I                                                      '
    61   '                                                            '
   121   '                                                            '
   181   '                                                            '
   241   '                                                            '
   301   '                                                            '
   361   '                                                            '
   421   '                                                            '
   481   '                                                            '
   541   '                                                            '
   601   '                                                            '
inputLeft   = %len(inp);
p_inputBuf  = %addr(inp: *data);
outputLeft  = %len(outp: *MAX);
%len(outp)  = outputLeft;
p_outputBuf = %addr(outp: *data);
P_INPUTBUF = SPP:C3770B08A6061462
INPUTLEFT = 6
P_OUTPUTBUF = SPP:C3770B08A6062A92
OUTPUTLEFT = 32766
rc = iconv( ictbl
          : p_inputBuf
          : inputLeft
          : p_outputBuf
          : outputLeft );
RC = 4294967295
I tried using the SendLine2 procedure instead of the SendLine procedure (so using ToASCII instead of iconv) and in this way the connection occurs correctly.
I can't do anything with the debug values of the variables -- I need to be able to reproduce the problem.
Cinzia
Post by Cinzia »
I enabled only the FTPS connection between two systems in both directions (CHGFTPA ALWSSL(*ONLY)) and set the certificates correctly.
I tested the FTPS in iterative and it works correctly.
These are the steps that the procedure takes:
WRK_SOCKET = FTP_open(P655.P655RCVSYS : FTP_PORT : 10); //P655.P655RCVSYS -> Name of system target
FTP_login(WRK_SOCKET : LDC_DDMUSR : P091.P091OUTDTA) // -> LDC_DDMUSR and P091OUTDTA are user and password
CALLP FTP_binaryMode(WRK_SOCKET:*ON);
CALLP FTP_passiveMode(WRK_SOCKET:*ON);
FTP_RmtCmd(WRK_SOCKET : WRK_CMCRTF) //WRK_CMCRTF = CRTSAVF DSCOBJDCMW/WO00050521
FTP_put(WRK_SOCKET : WRK_CMPUT1 : WRK_CMPUT2) // WRK_CMPUT1 and WRK_CMPUT2 = /qsys.lib/DSCOBJDCMW.lib/WO00050521.file
FTP_open happens with peTlsMode = FTPS_IMPLICIT and wwPort = 990
Everything up to the FTP_RmtCmd works correctly, the FTP_put fails when it goes to write the "TYPE I" with the iconv
I tried your code, and it all worked without problems for me.
     0: FTPAPI version 2.8 released on 2024-09-09
     1: 220-QTCP at LOOPBACK.
     1: 220 Connection will close if idle more than 5 minutes.
     1: > USER SKLEMENT
     1: 331 Enter password.
     1: > PASS **********
     1: 230 SKLEMENT logged on.
     1: > RCMD CRTSAVF DSCOBJDCMW/WO00050521
     1: 250 Command CRTSAVF DSCOBJDCMW/WO00050521 successful.
     1: > TYPE I
     1: 200 Representation type is binary IMAGE.
     1: > EPSV
     1: 229 Entering Extended Passive Mode (|||45685|).
     1: > STOR /qsys.lib/DSCOBJDCMW.lib/WO00050521.file
