http_req( but need the http code on failure
taylorDH0210
Post by taylorDH0210 »
This code is working fine. My only problem is when it fails, I cannot capture the HTTP status code, 401 for example.
The gReponse variable contains the text for the reason " {"message":"Invalid username/password."} ". I could force the errors and translate text to error codes, but I would rather not.
gResponseCode = http_req(
                'POST'
               : url
               : *OMIT       // File to receive
               : gResponse   // String to receive
               : gZipPath    // File to send
               : *OMIT       // gRequest
               : 'application/json' );
And, yes, I have found this so much better than reinventing the wheel. Merci beaucoup, Scott.
Re: http_req( but need the http code on failure
The 401 should be in gResponseCode in your example. Is it not?
taylorDH0210
Well, I did see that with another code, 404, but the 401 came out as -1. So did the timeout just now. I log the code and the message text.
404 | {"Message":"No HTTP resource was found that matches the request URI
-1 | {"message":"Invalid username/password."}
200 | {"StatusCode":200,"Message":null,"ProcessId":41697642,"BatchId":413342}
Oh, I bet 401 is expecting you to provide auth codes.
Try calling http_error and passing the 2nd optional parameter.
dcl-s status int(10);
...  code for http_req goes here ...
http_error(*omit: status);
You could also look for the HTTP_NDAUTH error code, if 401 means it needs authentication.
dcl-s err int(10);
... code to call http_req here ...
if rc = -1;
   http_error(err);
   if err = HTTP_NDAUTH;
      // http server asked for authentication.  Use http_setAuth() to provide it.
taylorDH0210
Will try today. Thanks for the quick response.
taylorDH0210
This worked great!
