ASCII Template PF used to print a form with logos on plain paper
NFCOChad
Post by NFCOChad »
We acquired a company years ago whose entire system is written in Sys36 and RPG 3. They have a printing process that uses an PF ASCII Template in a print command. The template produces all the lines, boxes, shading, and logos etc for a PO.
We need to update the logo and some of the box labels that the template produces.
We are clueless as to how to go about this. Any guidance would be greatly appreciated.
I can attach some docs when I am back in the office tomorrow.
Re: ASCII Template PF used to print a form with logos on plain paper
It is either RPG II on the System/36, or RPG III on the System/38. RPG III did not run on the System/36.
If you're interested in bringing me in as a consultant to help with your project, I'm available. I can send you an email.
NFCOChad
Post by NFCOChad »
I guess the point of mentioning RPG and RPG36 was to indicate that this is really old and hasn't been touched since 1997. We are on a Power9 that still has programs that are of "type" RPG36 and RPG.
This is the command we are dealing with
PRTASCII PRINTER(np5) SOURCEFILE(QTEMP/PRTPOFIL) +
TEMPLATE(DEETERPO) LOADTMPMCR(*YES) +
FONTID(4099) FONTPITCH(12) SAVE(*YES)
And attached is a snip of the form it creates. We want to swap out the logo.
How do we access the DEETERPO template to make modifications? I'm just looking for guidance on how to do it, I'm not looking for someone to do the work for us.
PO Example
PO Example
I'm guessing that PRTASCII is part of a third party product as I see no sign of it in any IBM docs and I have never heard of it.
What library is that command in?
NFCOChad
Post by NFCOChad »
It does appear to be a 3rd party command. We will go a different route and recreate the form in our current forms package.
