ACOM MrgFrmSpl
cooldude
ACOM MrgFrmSpl
Post by cooldude »
We are using ACOM product to convert spool file to PDF document. Today suddenly it erred out while executing the command "MrgFrmSpl" in batch process.
Error says -
Message text for FO10457 is: E-10457 No spool entries found
Any thoughts or suggestions?
Thanks!
Re: ACOM MrgFrmSpl
Have you contacted ACOM for technical support?
cooldude
Re: ACOM MrgFrmSpl
Post by cooldude »
Yes Scott. It was a system related issue where the spool file was not available during Merge. Thanks for the response!
Prakash.
