being HTTP used a lot to carry around a lot of redundant text in webservices calls, given the eventual benefits,
does HTTPAPI supports on the fly de/compression of the text payload, offloading to some api, or via filter/hooks possibility?
i.e. Accept-Encoding: gzip,deflate
seems commonly supported nowadays due to the savings due to high compressibility of xml or json.
thanks
encoding gzip , deflate
Re: encoding gzip , deflate
No, HTTPAPI does not have anything like that built-in. I have never had a need for it myself.
If you decide to add it, please consider contributing it back to the project.
