Yesterday I had an RPG-program where the XML-SAX command failed with error code 6.
After googling what this means, I found out that the cause was a character that couldn't
be converted from UTF-8 to EBCDIC. I think it was the "hat" ^
character that somebody had hit accidently.
This program is based on an article from Scott Klement in SystemINetwork from 14th May 2009
about XML-SAX. So it is fairly old.
xml-sax %handler(xmlHandler: ignoreMe) %XML(%trim( pFromstmf ) : 'doc=file');
My question is - is it possible to add code, so it replaces an invalid character with a blank
so I don't get an error?
Kind regards
Peder
XML-SAX failed with error code 6
Re: XML-SAX failed with error code 6
If you mean has anything changed with XML-SAX that would help with this the answer is no - nothing I can think of.
Only thing I can think of is to do a scan/replace operation. But that will take time so If the failure is infrequent, better to trap the error and run the scan/replace before a retry.
peder udesen
In the documentation for XML-SAX it is possible to specify that the data passed to
the XML-handler is in a certain CCSID. So it is possible to specify CCSID=1208 ( UTF-8 )
Normally with a single based character in EBCDIC format you can extract the value with
%subst(value:1:stringLen);
And in case you use UCS-2 that is a double based character you can extract the value with
%subst( ucs2val : 1 : %div(stringLen:2) );
But what do you do with UTF-8 that varies from 1 to 4 bytes pers character?
What I'm looking for is to have a variable with a string in UTF-8 format that is then moved to an EBCDIC variable
undergoing a conversion. In the manual we are told that "The substitution character for alphanumeric data is x'3F'."
for the case that an UTF-8 character can not be translated to an EBCDIC character
Then we could do something like this:
EBCDIC_value = UTF8_value;
EBCDIC_value = %xlate(x'3F' : ' ' : EBCDIC_value ); // convert x'3F' to a blank.
P xmlHandler B
D xmlHandler PI 10i 0
D ignore 1a
D event 10i 0 value
D string * value
D stringLen 20i 0 value
D exceptionId 10i 0 value
D value s 65535a based(String)
D ucs2val s 16363c based(String)
peder udesen
Does anybody have a good idea how to handle this?
