A correct sheet which cannot load
Attached is a zip file with an excel in it. If you open the excel (this works fine) and save it under another name (works as well). You get an excel which can be read by the XLSconvert program. However, the original file which is perfectly readable in excel cannot be read by XLSCONVERT. Files XLSCOLS and XLSOUTF in QTEMP are empty. What is wrong with this file so it is correct for Excel, but not for Klement's reading tools?
- Attachments
- voor.zip
- (18.43 KiB) Downloaded 2560 times
Re: A correct sheet which cannot load
After about 10 minutes of searching I discovered that XLSCONVERT is a tool from Easy400.net.
Unfortunately, I'm not familiar with this tool or what it supports. I would suggest checking out the support forums for Easy400 to find help.
My mistake, I thought it was one of your tools. Many thanks
