403 Forbidden Error
dave.c.hanneman
403 Forbidden Error
Post by dave.c.hanneman »
Here is my error log from a POST operation.
HTTPAPI Ver 1.42 released 2020-10-12
OS/400 Ver V7R3M0
https_init(): entered
QSSLPCL = *TLSV1.2
Old interface to TLS version 1.0 support disabled
TLS version 1.1 support disabled
initializing GSK environment
GSK Environment now available
DNS resolver retry  : 2
DNS default domain: RRD.COM
DNS server found: 10.79.131.126
DNS server found: 172.24.8.126
DNS server found: 172.24.14.21
SNI hostname set to: 10.79.190.14
Cert Validation Code = 0
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
Serial Number: 61:8E:A8:9B:03:69:B0
Common Name: corpdev2.rrd.com
Country: US
State/Province: Any
Org Unit: IBM Web Administration for i
Issuer CN: corpdev2.rrd.com_CERTIFICATE_AUTHORITY
Issuer Country: US
Issuer State/Province: Any
Issuer Org: IBM Web Administration for i
Version: 3
not before: 20211111114707
Unknown Field: 11:47:07 11-11-2021
not after: 20221112114707
Unknown Field: 11:47:07 12-11-2022
Unknown Field: 0382010F003082010A0282010100A86F5B7A29B547471A5FFC60B5943935EE3D5BE269857C948506069B775C832459281AC6BCE0C489C86D96F1C332C2B8A6B265E9BB5BEB0563856090E4C943B05FD98BB863EF01C9A9419FAA05967C40FB7C88E6072A9753E879090765DFF66B5479982D4D81016239A662D668355F37A7A49FD28E3132C30EA945A74D34E41FC1DE707352991BE869817AB6CC9A42346D2086D44559CD9607FC9FB47F19ECA5CA92B632BB18D4B39AFEE573A3409D168624549F2672EE9494C7A9B93A3A3B4E30654F017815FED8E1F2730177D650BD35A1EF5548C8D18BAB4E2E5324A0CA86B792D2B154026F3971AFB47A37EE4F2A179BAA5A20651EE2E744C03A7EF05B0D0203010001
Unknown Field: 2048
Unknown Field: E81C6520A315DC00A58DD7F200E37145
Unknown Field: C370C6DEE65E89A43F58D10BFD054D2BE3E8C4EC
Unknown Field: BD83A55B3D4619B47D9909EA9DFE3A3A5B5EEF6140EFD0EC4A026D57394C0D4E
Unknown Field: 23
POST /wbspgm/setliblt HTTP/1.1
Host: 10.79.190.14:443
User-Agent: http-api/1.43
SOAPAction:
Content-Length: 312
{"request": {    "signature":          "STSS",    "msg_no":             "1012",    "weight":             "2.45",    "length":             "0.00",    "width":              "5.25,      "height":             "0.05",    "package_type":       "0",    "system_id":          "1",    "package_id_barcode": "4453741799"}}
HTTP/1.1 403 Forbidden
Date: Mon, 15 Nov 2021 16:30:26 GMT
Server: Apache
Content-Length: 199
Content-Type: text/html; charset=UTF-8
SetError() #13: HTTP/1.1 403 Forbidden
recvresp(): end with 403
recvdoc parms: identity 199
recvdoc(): Receiving 199 bytes.
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<HTML><HEAD>
<TITLE>403 Forbidden</TITLE>
</HEAD><BODY>
<H1>Forbidden</H1>
<p>You don't have permission to access this resource.</p>
</body></html>
Here are my directives
# Configuration originally created by Create HTTP Server wizard on Thu Nov 11 12:56:39 CST 2021
LoadModule ibm_ssl_module /QSYS.LIB/QHTTPSVR.LIB/QZSRVSSL.SRVPGM
Listen *:443 https
DocumentRoot /www/jkltest/htdocs
TraceEnable Off
Options -FollowSymLinks
LogFormat "%h %T %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%{Cookie}n \"%r\" %t" cookie
LogFormat "%{User-agent}i" agent
LogFormat "%{Referer}i -> %U" referer
LogFormat "%h %l %u %t \"%r\" %>s %b" common
CustomLog logs/access_log combined
LogMaint logs/access_log 7 0
LogMaint logs/error_log 7 0
DefaultFsCCSID 37
DefaultNetCCSID 819
SetEnvIf "User-Agent" "Mozilla/2" nokeepalive
SetEnvIf "User-Agent" "JDK/1\.0" force-response-1.0
SetEnvIf "User-Agent" "Java/1\.0" force-response-1.0
SetEnvIf "User-Agent" "RealPlayer 4\.0" force-response-1.0
SetEnvIf "User-Agent" "MSIE 4\.0b2;" nokeepalive
SetEnvIf "User-Agent" "MSIE 4\.0b2;" force-response-1.0
SetEnv HTTPS_PORT 443
SSLEngine On
SSLAppName QIBM_HTTP_SERVER_JKLTEST
SSLCacheEnable
SSLVersion TLSV1.2_TLSV1.3
SSLProtocolDisable SSLv3 TLSv1 TLSv1.1
SSLClientAuth Optional
<Directory />
   Require all denied
</Directory>
<Directory /www/jkltest/earnings>
   AllowOverride None
   Require all granted
</Directory>
<Directory /www/jkltest/profiles>
   AllowOverride None
   Require all granted
</Directory>
<Directory /www/jkltest/htdocs>
   Require all granted
</Directory>
Alias /profiles/ /www/jkltest/profiles/
Alias /earnings/ /www/jkltest/earnings/
ScriptAliasMatch /wbspgm/([a-z0-9]+) /qsys.lib/w2gent.lib/$1.pgm
<Directory /qsys.lib/w2gent.lib>
   order allow,deny
   allow from all
</Directory>
<VirtualHost 10.79.190.14:443>
</VirtualHost>
Re: SSL problem
Hi Dave,
Is your question related to Frank's? Or, if not, can you tell us what your question is? You've provided a lot of information that we could use to investigate a problem, but you haven't told us what problem we should be investigating.
dave.c.hanneman
Re: SSL problem
Scott,
Yes, I am getting a persistent 403 error from the http server. I have directives for the program and data libraries in the http.conf
Re: SSL problem
I see. So it seems you added this onto Frank's "SSL problem" thread by mistake, since it doesn't seem to be related to SSL problems or Frank's post in any way. I will move it to a new thread for you.
You are connecting with HTTPAPI to an Apache HTTPD aand this is the URL you are submitting:
/wbspgm/setliblt
And if I'm reading it correctly, it is meant to match these directives:
   order allow,deny
   allow from all
</Directory>
However, thi s is using the old-school "order allow,deny" and "allow from all" directives, but the remainder of the config file using the newer syntax "Require all granted". I do not recommend mixing these two syntaxes... I would recommend changing it to this:
  Require all granted
</Directory>
Make sure you fully stop/start the HTTP server so that it picks up the changes.
