v1.52 - Getting "Pointer not set" error on http_url_post_stmf() call.
zeddave
Post by zeddave »
This is more of FYI, than a request for help, as I figured out a workaround, but I figured you'd like to know.
I just loaded v1.52, from v1.35.
Existing programs using the "http_url_post_stmf()" api were erroring on the optional "peSOAPAction" parameter not being set, when it tried to call "http_url_post_raw2()" api.
My workaround was to simply add an empty string as the last parameter to the api call.
I tried to pass *omit, but got the same erroring results.
Errored:
rc =
 http_url_post_stmf(
  g.url:
  g.tempMimeFile:
  g.responseFile:
  HTTP_TIMEOUT:
  HTTP_USERAGENT:
  http_type:
Resolved:
rc =
 http_url_post_stmf(
  g.url:
  g.tempMimeFile:
  g.responseFile:
  HTTP_TIMEOUT:
  HTTP_USERAGENT:
  http_type:
Below is the error I was getting and the source
From program . . . . . . . . . :   HTTPAPIR4
  From library . . . . . . . . :     LIBHTTP_52
  From module  . . . . . . . . :     HTTPAPIR4
  From procedure . . . . . . . :     HTTP_URL_POST_STMF
  From statement . . . . . . . :     7719
To program . . . . . . . . . . :   HTTPAPIR4
  To library . . . . . . . . . :     LIBHTTP_52
  To module  . . . . . . . . . :     HTTPAPIR4
  To procedure . . . . . . . . :     HTTP_URL_POST_STMF
  To statement . . . . . . . . :     7719
I debugged the process and it was pointing to this call in HTTPAPIR4.
0029.86 c                   eval      rc = http_url_post_raw2( peURL
0029.87 c                                                    : wwPostFD
0029.88 c                                                    : %paddr('read')
0029.89 c                                                    : wwDataSize
0029.90 c                                                    : wwRecvFD
0029.91 c                                                    : %paddr('write'
0029.92 c                                                    : wwTimeout
0029.93 c                                                    : wwUserAgent
0029.94 c                                                    : wwContentType
0029.95 c                                                    : wwSOAPAction
0029.96 c                                                    : wwDataSize64 )
Re: v1.52 - Getting "Pointer not set" error on http_url_post_stmf() call.
What error did you receive? You provided the call stack entries that the error message was sent from/to, but you didn't provide the message itself.
