Show message on line 24 of interactive display after RPG program ends
nelsong1997
Post by nelsong1997 »
I am having trouble showing a message on line 24 of an interactive display that persists after an RPG program ends.
I was able to get this to work with SNDPGMMSG in a CL program.
SNDPGMMSG  MSGID(CPF9897) MSGF(QCPFMSG) MSGDTA('EXAMPLE') TOPGMQ(*EXT) MSGTYPE(*COMP)
However, if I call this CL program from within an RPG program, the message goes away when the RPG program ends.
The closest I can get is to get a message to show on a separate screen with "Display Program Messages."
I was able to do this in two ways:
1. Calling a CL program that does a SNDPGMMSG like this:
SNDPGMMSG  MSGID(CPF9897) MSGF(QCPFMSG) MSGDTA('EXAMPLE') TOPGMQ(*EXT) MSGTYPE(*INFO)
2. Using SND-MSG within the RPG program itself:
SND-MSG *INFO 'EXAMPLE' %TARGET(*EXT);
Is there any way to get the message to show on line 24, the same way it works with a CL program?
Please let me know if there is any more information I should provide about the scenario I am describing.
Thanks!
Re: Show message on line 24 of interactive display after RPG program ends
*COMP means "completion message" -- i.e. it is what shows when a program completes.
Since you have another program that is ending after the CL, it replaces it because now that program is completing. (Assuming I understand your scenario, anyway.)
You say you are able to see it if you do it as an *INFO message in a separate Display Program Messages screen -- that makes perfect sense since sending a program message to *EXT shows on that screen.
I guess you could retrieve the completion message from the CL program and re-send it as a completion message from the RPG program... it seems a little strange, but... I guess I wonder why you want to do this?
At any rate, the RPG program can do it like this (if you're up-to-date on PTFs):
SND-MSG *COMP 'EXAMPLE' %TARGET(*CALLER: 1);
Support for SND-MSG to send *COMP messages was added (via PTF) in Spring 2024.
nelsong1997
Thank you, that worked.
Not for any really good reason. It was just driving me crazy because I knew it was possible somehow but I couldn't quite figure it out.
Thanks again
