HTTP_POINT_ADDL_HEADER Header parameters
twisteddisco
Post by twisteddisco »
Hello All,
Question on the HTTP_POINT_ADDL_HEADER routine.
I have a requirement where I need to create a webservice which will include HEADER parameters and a REQUEST body.
The HEADER parameters are:
IvUserKey
ivUserBic
The Request Body parameters are:
party
partyAccount
I have never used HTTPAPI to add header parameters, looking at existing posts I think I need to do something like this using
// Notify httpapi of the routine to use to add headers
http_xproc( HTTP_POINT_ADDL_HEADER: %paddr(AddHeaders));
// Perform the http request and get back the response
Monitor;
wResponse = http_string('POST': wUrl: eJsonString: 'application/json');
dcl-proc AddHeaders;
  dcl-pi *n;
    toBeAdded varchar(32767);
  toBeAdded = 'IvUserKey: valuea' + x'0d25'
     		   + 'ivUserBic: valueb' + x'0d25';
 end-proc;
Is this the correct way to go about this?
Thankyou for your time, much appreciated
Re: HTTP_POINT_ADDL_HEADER Header parameters
It looks correct to me.
sathis_nsk
Post by sathis_nsk »
Just an additional info.
I used the following statement to register a header handler:
http_xproc( HTTP_POINT_ADDL_HEADER  : %paddr(Add_headers) );
However, I noticed that subsequent HTTP requests to different endpoints (such as the authentication token request) within the same program continued to carry over the same headers.
To resolve this, I had to explicitly deregister the header handler after each HTTP request by using:
http_xproc( HTTP_POINT_ADDL_HEADER  : *NULL );
Yes, that is the expected behavior.
twisteddisco
It seems my authorisation header needs to be in BASE64, for this I have downloaded Scott's BASE64R4 program.
The program BASE64R4 makes perfect sense (Thanks Scott) but I just wondered about the format of the data when I add it to header, once converted does it still need the CRLF at the end?
For example:
My details are:
User Id: demo
Password: p@55w0rd
When encoded to BASE64 this looks like ZGVtbzpwQDU1dzByZA==
The format of the authorization header should be Authorization: Basic ZGVtbzpwQDU1dzByZA==
Support for that is built-in. Just do this before your request:
http_setauth(http_auth_basic : 'demo' : 'p@55w0rd' );
...http_string...and other code here...
After you are done, remove the password from memory...
http_setauth(http_auth_none:'':'');
twisteddisco
Passing JWT in Request Body
Hi All,
First of all thankyou for your help now and in the past, much appreciated.
The requirements for my program have move on slightly.
Authorization Header
Your application credentials, client_id and client-secret of the app you created, are exchanged through the Basic Authentication Scheme in the authorization header. Calculate the base-64 encoded value of client_Id:client_secret and use it in the authorization header with the keyword Basic in front of it.
Request Body
Depending on the data sensitivity behind the APIs you are trying to access, you will be applying one of the two authorisation grant types: Password Grant Type or JWT Bearer Grant Type. We need JWT Bearer Grant Type
For APIs using JWT Bearer grant type, you must generate a JSON Web Token (JWT) using your Swift-issued PKI certificates.
Parameters Values Descriptions
grant_type urn:ietf:params:oauth:grant-type:jwt-bearer Use the value as is.
scope RBAC role/qualifiers example xxx.xxxx,api!p
assertion Signed JSON Web Token This value is the signed JWT containing the claims and signed by your channel certificate
To achieve the creation of the JWT I have a new program based on the findings in the following URL:
This creates a long base64 encoded string that does validate in JTW.IO so I am fairly happy this is correct, more on this later...
When I then process this in the program it the code looks as follows:
//█Set Options
http_setOption('timeout': '30');
http_setOption('network-ccsid': '1208' );
http_use_cookies(*OFF);
tokenendpoint = %Trim(wAuthUrl);
resultStr         = *Blanks;
GrantType       = 'urn:ietf:params:oauth:grant-type:jwt-bearer';
http_setAuth( HTTP_AUTH_BASIC
            : %trim(client_id)
            : %trim(client_secret) );
sendData = 'grant_type=' + %trimr(http_urlEncode(%trimr(GrantType))) +
                  '&scope='+ %trimr(http_urlEncode(%trimr(wScope)))       +
                  '&assertion=' +%trimr(JsonWebToken);
rc = http_req( 'POST'                   // Type
              : tokenendpoint            // Url
              : *omit                          // Result Stmf
              : resultStr                     // String to receive the results
              : *omit                          // Send Stmf
              : sendData                    // Send String
              : 'application/x-www-form-urlencoded'); // Content
When the program runs under debug I can see the following values:
SENDDATA =
     1   'grant_type=urn%3Aietf%3Aparams%3Aoaut&scope=eba.step2.api!p&'
    61   'assertion=eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsIng1YyI6WyJNSU'
   121   'lFeGpDQ0FxNmdBd0lCQWdJRWFLcDIwVEFOQmdrcWhraUc5dzBCQVFzRkFEQV'
   181   'FNUTR3REFZRFZRUUtFd1ZUVjBsR1ZEQWVGdzB5TlRBNE1qZ3hNek0wTVRaYU'
   241   'Z3MHlOekE0TWpneE5EQTBNVFphTUVZeERqQU1CZ05WQkFvVEJYTjNhV1owTV'
   301   'JFd0R3WURWUVFLRXdobGJtbGlZbVZpWWpFT01Bd0dBMVVFQ3hNRmMzUmxjRE'
grant_type seems to be urlencoded correctly!
scope also seems to be urlencoded correctly!
So the result back from the call is as follows:
2025-09-04-11.09.12.255703: recvdoc(): Receiving 141 bytes.
{ "error":"invalid_request", "error_description":"OAuth token grant request is malformed." }
2025-09-04-11.09.12.255736: recvdoc(): have 141 of 141
2025-09-04-11.09.12.255756: SetError() £13: HTTP/1.1 400 Bad Request
I believe the malformed Oauth token grant request is caused by certain information in the JWT not being correct, such has fields in the payload body. These will be clarified by the API provider
I have written previous webservices to get OAUTH2 using user and password but none that need to pass a JWT.
Does the code above look correct or am I missing something?
I'm not familiar with using a JWT this way. You'll need to consult the documentation for the authorization server you are communicating with.
twisteddisco
Thankyou for the reply.
For some reason your Forum section was down for a week so I could not read your reply.
The passing of the JWT in the SENDDATA string works fine. The malformed message I was getting was down to mis information from the Vendor as to the actual content of the Claim within the JWT. This has been correct and now all works fine.
