HTTP/1.1 401 Unauthorized
twisteddisco
Post by twisteddisco »
Hi All,
Could do with some advice if anyone can help or shed light on an error I am getting.
My process is as follows:
1.) Create JWT to get OAUTH2 token, supplying user id and password
2.) Apply token
3.) Call webservice to use the applied token
I create a JWT to be able to get an OAUTH2 token, this works fine and gives me the OAUTH2 token, to get this I do the following
Get the OAUTH2 Token
http_setAuth( HTTP_AUTH_BASIC
            : %trim(client_id)
            : %trim(client_secret) );
sendData = 'grant_type=' + %trimr(http_urlEncode(%trimr(GrantType))) +
           '&scope='+ %trimr(http_urlEncode(%trimr(wScope)))       +
           '&assertion=' +%trimr(JsonWebToken);
rc = http_req( 'POST'                    // Type
              : tokenendpoint            // Url
              : *omit                    // Result Stmf
              : resultStr                // String to receive the results
              : *omit                    // Send Stmf
              : sendData                 // Send String
              : 'application/x-www-form-urlencoded'); // Content
If rc <> 1;
  wAuthMsg    = http_error(*omit: wErrorStatus);
  Oauth2Error = 'Y';
Else;
  data-into AuthResultDs %DATA(resultStr) %PARSER('YAJLINTO');
Endif;
// Remove user and password from memory
http_setauth(http_auth_none: '':'');
// Set authority
HTTP_setAuth( HTTP_AUTH_BEARER: '':
              %trimr(AuthResultDs.access_token));
Once I have the oauth2 token and the authorisation has been set I proceed to call the webservice as follows:
// Add headers...
http_xproc( HTTP_POINT_ADDL_HEADER: %paddr(AddHeaders));
// Perform the http request and get back the response
Monitor;
wResponse = http_string('POST': wUrl: JsonRequest: 'application/json');
  // Monitor for error in calling request..
  On-error;
 .... Process the error etc
Endmon;
// Clear Oauth2 token from memory
rc = http_setAuth(HTTP_AUTH_NONE : ' ' : ' ' );
// Delete the additional header added so not to confuse the next request
http_xproc( HTTP_POINT_ADDL_HEADER  : *NULL );
// Free up Json processor
yajl_tree_free(docNode);
When I look at the log I am getting the following error, confused now as I do not know what the actual error is.
In the log you can see the Authorization: Bearer One2EiN1Oag1WAbRXAnr06Z50sEQ which proves the Oauth2 token was applied.
Header values can be seen also, these are correct and have been verified (Values takes out for security)
IvUserKey:cn=xxxx
ivUserBic:xxxxx
senderBic:xxxxx
pri:xxxx
X-Request-Timestamp:2025-09-12T11:09:37.693+02:00
is the error I am not authorised or that the site needs a user and password?
I saw somewhere Scott commented that the user and password message is sometimes confusing and sometimes not correct.
That said, I am looking at the "not authorised message".
The log looks as follows:
HTTPAPI Ver 1.49 released 2024-04-16
OS/400 Ver V7R5M0
2025-09-12-11.09.37.725587: http_persist_open(): entered
2025-09-12-11.09.37.729251: http_long_ParseURL(): entered
2025-09-12-11.09.37.729307: DNS resolver retrans: 2
2025-09-12-11.09.37.729320: DNS resolver retry  : 2
2025-09-12-11.09.37.729332: DNS resolver options: x'00000136'
2025-09-12-11.09.37.729352: DNS default domain: ENI.COM
2025-09-12-11.09.37.729366: DNS server found: 10.10.10.140
2025-09-12-11.09.37.729378: DNS server found: 10.10.10.10
2025-09-12-11.09.37.729393: Resolving host api-test.xxxx.sipn.xxxx.com
2025-09-12-11.09.37.729411: inet_addr return value for this host is 4294967295
2025-09-12-11.09.37.729440: gethostbyname() returned 2508603163
2025-09-12-11.09.37.729453: Looking up service https
2025-09-12-11.09.37.729472: Service table returns port 443
2025-09-12-11.09.37.729514: Nagle's algorithm (TCP_NODELAY) disabled.
2025-09-12-11.09.37.741421: SNI hostname set to: api-test.xxxx.sipn.xxxx.com
2025-09-12-11.09.37.821113: -------------------------------------------------------------------------------------
2025-09-12-11.09.37.821141: Dump of server-side certificate information:
2025-09-12-11.09.37.821153: -------------------------------------------------------------------------------------
2025-09-12-11.09.37.821166: Cert Validation Code = 6000
2025-09-12-11.09.37.826436: -----BEGIN CERTIFICATE-----
Taken out for log for security=
2025-09-12-11.09.37.826541: -----END CERTIFICATE-----
Serial Number: 67:5E:49:88
Common Name: api-test.xxxx.sipn.xxxx.com
Country: ww
Org Unit: swift
Org: operational
Issuer Org: xxxx
Version: 3
not before: 20250107064759
Unknown Field: 06:47:59 07-01-2025
not after: 20290107071759
Unknown Field: 07:17:59 07-01-2029
Unknown Field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
Unknown Field: 2048
Unknown Field: 940C10B26892F5ABDA2415504600C851
Unknown Field: 5C9263F27D1E6A02A43A4EC7EA809E48DFE72D11
Unknown Field: 3E9D67428382498148E8D9F17F2908CBB7D49BACCF285B28F8A0BF3B4993A087
Unknown Field: 5
Unknown Field: api-test-nl-mon.xxxx.sipn.xxxx.com
Unknown Field: api-test-ch-mon.xxxx.sipn.xxxx.com
Unknown Field: api-test.xxxx.sipn.xxxx.com
Unknown Field: 0
Unknown Field: 1.3.21.6.6.10.100.5
Unknown Field: CN=CRL5855,O=SWIFT
2025-09-12-11.09.37.827542: Protocol Used: TLS Version 1.2
2025-09-12-11.09.37.827565: http_persist_req(POST) entered.
2025-09-12-11.09.37.827592: http_long_ParseURL(): entered
2025-09-12-11.09.37.827625: http_long_ParseURL(): entered
2025-09-12-11.09.37.827718: do_oper(POST): entered
2025-09-12-11.09.37.827753: CommSSL_BlockWrite(): gsk_secure_soc_write socket fd=1, flags=00000084, blocking=0
2025-09-12-11.09.37.827791: CommSSL_BlockWrite(): gsk_secure_soc_write rc=0, len=234
POST /xxxx-xxxx-pilot/v1/xxxx/xxxx/vop HTTP/1.1
Host: api-test.xxxx.sipn.xxxx.com
User-Agent: http-api/1.48
Content-Length: 5000
2025-09-12-11.09.37.827811: CommSSL_BlockWrite(): gsk_secure_soc_write socket fd=1, flags=00000084, blocking=0
2025-09-12-11.09.37.827831: CommSSL_BlockWrite(): gsk_secure_soc_write rc=0, len=187
IvUserKey:cn=xxxx
ivUserBic:xxxxx
senderBic:xxxxx
pri:xxxx
2025-09-12-11.09.37.827850: CommSSL_BlockWrite(): gsk_secure_soc_write socket fd=1, flags=00000084, blocking=0
2025-09-12-11.09.37.827869: CommSSL_BlockWrite(): gsk_secure_soc_write rc=0, len=2
2025-09-12-11.09.37.827886: senddoc(): entered
2025-09-12-11.09.37.827899: senddoc(): data left=5000, chunk size=5000, timeout=30, calling comm_blockWrite...
2025-09-12-11.09.37.827912: CommSSL_BlockWrite(): gsk_secure_soc_write socket fd=1, flags=00000084, blocking=0
2025-09-12-11.09.37.827941: CommSSL_BlockWrite(): gsk_secure_soc_write rc=0, len=5000
*****Request body was here, taken out for security****
2025-09-12-11.09.37.827956: senddoc(): comm_blockWrite returned 5000
2025-09-12-11.09.37.827968: recvresp(): entered
2025-09-12-11.09.37.827981: recvresp: reading response header, space left=32767
2025-09-12-11.09.38.231087: recvresp: reading response header, space left=32740
Date: Fri, 12 Sep 2025 09:09:38 GMT
2025-09-12-11.09.38.231121: recvresp: reading response header, space left=32703
2025-09-12-11.09.38.231136: recvresp: reading response header, space left=32671
Content-Length: 0
2025-09-12-11.09.38.231152: recvresp: reading response header, space left=32652
Connection: keep-alive
2025-09-12-11.09.38.231167: recvresp: reading response header, space left=32628
Strict-Transport-Security: max-age=31536000; includeSubDomains
2025-09-12-11.09.38.231961: recvresp: reading response header, space left=32564
X-XSS-Protection: 1; mode=block
2025-09-12-11.09.38.231978: recvresp: reading response header, space left=32531
2025-09-12-11.09.38.231993: recvresp: reading response header, space left=32498
Content-Security-Policy: default-src https: data: 'unsafe-inline' 'unsafe-eval'
2025-09-12-11.09.38.232008: recvresp: reading response header, space left=32417
X-Frame-Options: SAMEORIGIN
2025-09-12-11.09.38.232022: recvresp: reading response header, space left=32388
vary: Origin,Access-Control-Request-Method,Access-Control-Request-Headers
2025-09-12-11.09.38.232037: recvresp: reading response header, space left=32313
x-content-type-options: nosniff
2025-09-12-11.09.38.232051: recvresp: reading response header, space left=32280
x-xss-protection: 0
2025-09-12-11.09.38.232066: recvresp: reading response header, space left=32259
cache-control: no-cache, no-store, max-age=0, must-revalidate
2025-09-12-11.09.38.232080: recvresp: reading response header, space left=32196
pragma: no-cache
2025-09-12-11.09.38.232094: recvresp: reading response header, space left=32178
expires: 0
2025-09-12-11.09.38.232109: recvresp: reading response header, space left=32166
strict-transport-security: max-age=31536000 ; includeSubDomains
2025-09-12-11.09.38.232123: recvresp: reading response header, space left=32101
x-frame-options: DENY
2025-09-12-11.09.38.232138: recvresp: reading response header, space left=32078
x-envoy-upstream-service-time: 49
2025-09-12-11.09.38.232152: recvresp: reading response header, space left=32043
Set-Cookie: 9dd82f42f18f840982bf322df7490b52=d9146d194789702345cdc3f9901f4f83; path=/; HttpOnly; Secure; SameSite=None;HttpOnly;Secure
2025-09-12-11.09.38.232166: recvresp: reading response header, space left=31907
X-Request-ID: nlartl52-1055975-47977092-1
2025-09-12-11.09.38.232181: recvresp: reading response header, space left=31864
Set-Cookie: TS013f97cf=01d40caef1d62f6d7aa2959361c0a192333386f886cfe20e0046e06643eb4c9177b6c5eab694fb89f8a1d3aa1d1efded8f87e59c45; Path=/; Secure; HttpOnly
2025-09-12-11.09.38.232196: recvresp: reading response header, space left=31707
2025-09-12-11.09.38.232210: recvresp: empty line, ending header, number of eol chars=2
2025-09-12-11.09.38.232228: recvresp: header resp code = 401  repeating=0
[b]2025-09-12-11.09.38.232244: SetError() £13: HTTP/1.1 401 Unauthorized[/b]
2025-09-12-11.09.38.232256: recvresp(): end with 401
2025-09-12-11.09.38.232279: recvdoc parms: identity 0
[b]2025-09-12-11.09.38.232295: SetError() £36: This page requires a user-id & password[/b]
2025-09-12-11.09.38.232339: recvdoc(): entered
2025-09-12-11.09.38.232351: SetError() £0:
2025-09-12-11.09.38.232363: recvdoc(): Receiving 0 bytes.
2025-09-12-11.09.38.232374: recvdoc(): Nothing to receive, exiting...
[b]2025-09-12-11.09.38.232386: SetError() £36: This page requires a user-id & password[/b]
2025-09-12-11.09.38.232411: http_close(): entered
Re: HTTP/1.1 401 Unauthorized
The "401 Unauthorized" means that the authorization you are sending is not working in some way. Perhaps they aren't the right credentials, or perhaps you are sending them in the wrong format. That's about all I can tell you for certain.
Please turn off all the "level 2" logging, this makes the log really hard to read. There's a reason this stuff isn't turned on by default.
