401 - Bad Request on DELETE
kathan.p@gmail.com
Post by kathan.p@gmail.com »
Hi, Since yesterday suddenly http_string('DELETE') started giving HTTP 401 Bad Request..
   HTTP_debug(*on);
   http_setCCSIDs( 1208: 0 );
   HTTP_SetFileCCSID(1208);
              : %paddr(add_headers) );
        server = %trim(pltinturl) + %trim(pltitjobep) + jobid;
               response = http_string('DELETE': server);
  errorMsg = http_error();
Server variable = Url with JOB id which will delete the data from site.
add_headers - this will get the bearer token saved on the system and attach to header.
whenever it tries to do DELETE it will give us BAD REQUEST
so later on as a fix we started creating new bearer token every time a DELETE is request and it worked. I know this is not the correct solution but it worked.
We are using DELETE on other client servers as well with same method and it's working fine no issues but for this particular server it started happening yesterday only and there was no PTF or any change on the server.
any advise why DELETE is suddenly started giving BAD REquest and after generating token on every request it resolved.
HTTPAPI Ver 1.40 released 2019-08-15
OS/400 Ver V7R2M0
http_persist_req(DELETE) entered.
do_oper(DELETE): entered
DELETE /api/jobs/8763308-01/?id_type=external     HTTP/1.1
Host: wei.pltsci.com
User-Agent: http-api/1.39
api-version: 2.0
Authorization: Bearer eyJ0eXAiOiJKV1QiLCJhbGciOiJSUzI1NiIsImp0aSI6IjZmZmNjN
HTTP/1.1 400 Bad Request
Server: awselb/2.0
Date: Wed, 24 Nov 2021 21:38:44 GMT
Content-Type: text/html
Content-Length: 122
Connection: close
recvresp(): end with 400
recvdoc parms: identity 122
recvdoc(): Receiving 122 bytes.
<html>
<head><title>400 Bad Request</title></head>
<body>
<center><h1>400 Bad Request</h1></center>
</body>
</html>
Re: 401 - Bad Request on DELETE
I can see that there is something strange about both your URL and your bearer token. Please verify that these do not have extra spaces or other unprintable characters in them.
kathan.p@gmail.com
This was resolved, it was an issue while doing handshake ... thank you
