Chunk size
twisteddisco
Chunk size
Post by twisteddisco »
Hi All,
I have written a program that will receive a large response from a web service call using the following HTTP_REQ with the results going back into a Stream file in the IFS.
rc = http_req( 'GET'                                    // Type
              : wResultUrl                              // Url
              : %Trimr(wResultsFile)                    // Result Stmf
              : ResultStr                               // String to receive
              : *omit                                   // Send Stmf
              : *omit);                                 // Send String
One thing I have noticed looking at the log is the word "Chunking"
HTTPAPI Ver 1.49 released 2024-04-16
OS/400 Ver V7R5M0
http_setauth(): entered
etc...
SetError() £13: HTTP/1.1 200 OK
recvresp(): end with 200
recvdoc parms: chunked 0
recvchunk(): entered
get_chunk_size(): entered
7937
chunk size = 31031
get_chunk_size returned 31031
calling comm_blockread
etc... Data received (Hidden)
0
chunk size = 0
get_chunk_size returned 0
OS/400 Ver V7R5M0
Looking on the internet to see what this actually means I found this link which mentions upgrading the HTTPAPI, is this correct still?
Having never upgraded before if this is needed, are there any special requirements in re compiling etc?
Thanks All
https://archive.midrange.com/rpg400-l/ ... 0032.html
Re: Chunk size
What problem are you trying to solve?
