Inquiry on Software Compatibility with IBM i V7R5
Andanet
Post by Andanet »
We are currently planning an upgrade to IBM i V7R5 and would like to know if your software is fully compatible with this release. Our currently installed version is 1.48.
Re: Inquiry on Software Compatibility with IBM i V7R5
HTTPAPI is compatible with V7R1 and newer, so yes. The current version is 1.52, and I do recommend updating to this when you are able to.
Andanet
Post by Andanet »
