Does this support SFTP?
Does the FTPAPI support SFTP?
Re: Does this support SFTP?
By "SFTP", do you mean the FTP-like interface for SSH? If so, that isn't actually FTP, it's just SSH with commands that are similar to FTP. It works really well, though... I'm glad to answer questions about OpenSSH if that's what you're using.
But, no, FTPAPI does not support it.
There is also a similar name "FTPS" which is FTP over SSL. This is the same protocol that FTPAPI provides, but I never added SSL support to FTPAPI. Other people have done so on their own, though. Personally, I would recommend using SFTP (SSH) instead. FTPS is, in my opinion, putting lipstick on a pig.
Hi NStone, if you need a native sftp api on OS/400, and you are familiar in C, see the libssh2 project on GitHub. It has an OS/400 version (but I think, they never use it
It supports OS/400 crypto APIs. It is possible to build/make an usable sftp API from it.
SFTP isn't FTP. They are completely different network protocols. SFTP is a command-line interface to some of the functionality of SSH.
So, no.. FTPAPI doesn't support SFTP. And never will.
Just use OpenSSH. It works really well.
Hi Scott, you mentioned in your post that there are people who have implemented ftpS into the FTPAPI. Do you have the code of one of these implementations available and are willing to share it? Or can you forward my request to one of these people? Feel free to forward my email address. Thanks.Scott Klement wrote: Wed Aug 04, 2021 8:27 pm By "SFTP", do you mean the FTP-like interface for SSH? If so, that isn't actually FTP, it's just SSH with commands that are similar to FTP. It works really well, though... I'm glad to answer questions about OpenSSH if that's what you're using.
(Unfortunately, we have to put up with the pig with lipstick.
I didn't save the information or code, sorry. Maybe they'll see this message and reply.
Hi MarkusN, you can find the ftps modification of ftpapi made by Craig Strong as an attached zip file in mailing archive 2007/04, in list 'FTP SSL support'.MarkusN wrote: Thu Oct 21, 2021 3:08 pm Hi Scott, you mentioned in your post that there are people who have implemented ftpS into the FTPAPI. Do you have the code of one of these implementations available and are willing to share it? Or can you forward my request to one of these people? Feel free to forward my email address. Thanks.
(Unfortunately, we have to put up with the pig with lipstick.)
The zip file also includes suggestions of Scott, please consider them when you implement the update.
I implemented it into my ftpapi with recommended modifications and it is working. I have found one error only: the modification does not close the secure channel when no more data to transfer. Please implement a gsk close before close socket:
c if wwRC < 1
if wkSSLBh <> *null;
gsk_secure_soc_close(wksslbh);
wksslbh = *null;
c callp close(wwSock)
c return 0
c endif
Hi kabelnet,
is it possible that you share your version for FTPS here?
He was referencing this message: https://www.scottklement.com/archives/f ... 00015.html
Hello Scott,
I already found that message. But it's good to have the link here, so others don't have to search for it.
What I meant:
kabelnet seems to have a version of FTPAPI with support of FTPS. So I asked him to upload his version, so that all interested in FTPS don't have to do the changes by their own.
What I meant:
