Problem in the latest zip installation file (1.47 according to CHANGELOG)
zenovalle
Post by zenovalle »
just a warning: I was installing the latest version from the ZIP file but there is a problem with the CMD members in QCMDSRC, they are void and the CMD creation fails.
For now I'm going to copy them from an older version if they're not changed.
Roberto.
Kyros
Re: Problem in the latest zip installation file (1.47 according to CHANGELOG)
Post by Kyros »
Hi Roberto,
i can confirm that i have the same exact problem you are describing.
Do you mind sharing the older version of HTTPAPI that you used so i can do the same? (i can't seem to find older versions of HTTPAPI available to the public).
Did copying from the older version fix the error?
Fabio
Miras
Post by Miras »
you can install the HTTP 1.47 using save file, which you can download from https://www.scottklement.com/httpapi/httpapi.savf.
Installation instructions are available at https://www.scottklement.com/httpapi/httpapi_savf.html
This save file contains the HTTPAPI *CMD object compiled. It contains the EXAMPLE9 *PGM object compiled too
Regards
Miras
These problems should be fixed in version 1.48, which is now on https://www.scottklement.com/httpapi/
