Subscription Key in Header
balinabk
Post by balinabk »
We are trying to pass a json data to an APIM server using HTTPAPI in RPGLE. We tried to provide the subscription key using http_setAuth method but they are asking to send this in header. How to define the subscription key in Header to connect an APIM server using RPGLE? Following is our program.
* Program Id : WT1
* File Desc : Test AS400/web service for Pick Pack shiphip
* Author : Thisaru Dheerarathna
* Date : 25/09/2024
/if defined(*CRTBNDRPG)
H DFTACTGRP(*NO)
/endif
H BNDDIR('HTTPAPI')
/copy httpapi_h
/copy ifsio_h
D QCMDEXC pr extpgm('QCMDEXC')
D command 200A const
D length 15P 5 const
D msg s 52A
H BNDDIR('HTTPAPI')
/copy httpapi_h
/copy ifsio_h
D msg s 52A
D rc s 10I 0
D url S 256A
D jsonFilePath S 256A
D ContentType s 256A
**FREE
http_debug(*on:'/tmp/baba-diagnostic-log.txt');
jsonFilePath =
'/NPS/PMMK/PMMK321_20241006_230519_20241006230519114.JSON';
http_setOption('content-type': 'application/json');
rc = http_req( 'POST'
:'https://endpoint URL'
: '/tmp/testpost.html' // File to receive
: *omit // String to receiv
: jsonFilePath // File to send
: *omit); // String to send
Any guidance will be helpful. If you need any further information, feel free to contact me.
Re: Subscription Key in Header
What is the header you need to pass it in? Do you have an example of what it looks like?
balinabk
Post by balinabk »
We need to pass the following values for authorization.
Key name and key value lime api-key: "key value".
balinabk
Post by balinabk »
Thanks for the information Scott. We managed to resolve the issue by using additional headers exit point process in HTTPAPI.
